Help regarding steam or smoke coming from an exhaust component, time sensitive.. - Page 3 - SailNet Community
post #21 of 28 Old 02-17-2011
I'd rather be sailing
labatt's Avatar
Ditto on the pink vs. green antifreeze. The pink stuff is non-toxic and can even be used for winterizing your potable water systems. Just in case you used the green antifreeze for the potable system - I would flush it out about 20 times and bleach it and scrub all the nooks and crannies before drinking water out of them.
With regards to the white smoke, this is not usually unburnt diesel but post-combustion water vapor. Diesel burns black, oil burns blue. Water burns white. White smoke from the exhaust during warmup is normal. If it continues it could mean water contamination of your fuel or water entering your cylinders somehow. If it was a head gasket issue the exhaust should be blue in color - not white. (others - please correct me if I'm wrong).
With regards to your engine RPM's and raw diesel - at higher RPM's a diesel engine can easily not burn all of the fuel injected into the cylinders. Once again, this is not out of the norm. Our boat regularly ejects small amounts of unburnt diesel at start (cold engine) or during/after docking procedures where we have several high RPM run-ups to add steerageway or slow the boat down. If it's constantly ejecting unburnt diesel that is a whole different problem.
I also noticed that you have single clamps on your mixing elbow for both the raw water intake and the gas/exhaust intake. With the vibrations they go through I would highly recommend double clamping them.
s/v "Pelican" Passport 40 #076- Finished Cruising - for the moment -
"Don't dream your life, live your dream" - Bob Bitchin'
"I'll see it when I believe it" - Me
labatt is offline
post #22 of 28 Old 02-17-2011
Originally Posted by chrisncate View Post
Coming up on the key bridge ..
And everybody can relax, while I did use green Antifreeze , none was spilled or discharged as we capture it with a large 5 gallon bucket. We put nothing in the water.
Phew!
Still, I don't think there is any reason to use the green antifreeze (ethylene glycol) for winterizing. To begin with, the pink stuff is a lot cheaper. And you don't have to worry about spills.
MastUndSchotbruch is online now
post #23 of 28 Old 02-17-2011
It is a poison, just nowhere near as toxic as the green stuff. Still not great for sealife... just not as poisonous.
Originally Posted by captbillc View Post
if you are going to run antifreeze through the sea water side it should be pink RV antifreeze that is not a poison.
sailingdog is offline
post #24 of 28 Old 02-17-2011
the pointy end is the bow
erps's Avatar
On another issue from your OP. You were in rough conditions and then the engine wouldn't go above 2500 rpm's. That's a textbook case for a partially clogged fuel filter. The gunk in the tank gets churned around in the rough conditions and then clogs the filter. Change filter(s) and you should have full rpm back.
I absolutely agree and would add that any exhaust gases escaping the exhaust elbow that can be sucked back into the air intake can also decrease engine rpm's. Had personal experience with a Honda outboard that wouldn't run unless the engine cover was off. Took a while to figure that one out.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
erps is offline
post #25 of 28 Old 02-17-2011
You are right, the pink stuff is somewhat toxic, too. But what is the alternative? For the drinking water supply, cheap vodka has been suggested many times.
Dunno, would that work in a motor?
(of course, ethanol is a poison too...)
post #26 of 28 Old 02-17-2011
Tartan 27' owner
CalebD's Avatar
Chris,
Take some pictures or it did not happen!
Everybody has one:
CalebD is offline
post #27 of 28 Old 02-17-2011
Boasun's Avatar
Well if you accidently dumped some cheap Vodka over the side you may end up with some drunk little fishies trying to pick a fight with a shark...
1600 Ton Master, 2nd Mate Unlimited Tonnage
Maritime Instructor
S/V Rapture
Boasun is offline
post #28 of 28 Old 02-17-2011
MacGyverRI's Avatar
Good job!
Don't tighten the stuffing box too much, 4-6 drips a minute while running is perfect.
Ken, East Prov., R.I. Bootlegger, PY26 Paceship
If you like my posts, or they were helpful, please click the "scales" icon on top right to add Rep points.
MacGyverRI is offline
Another Exhaust Smoke Diagnosis DrB Diesel 1 07-06-2010 09:46 AM
White smoke coming from my Perkins 4108? SanDiegoChip Gear & Maintenance 5 10-06-2009 12:01 PM
Exhaust Steam Sixbrothers Diesel 3 09-06-2009 05:19 PM
Wax job and exhaust smoke grinfax Gear & Maintenance 3 10-26-2008 08:19 PM
Exhaust smoke winethief Gear & Maintenance 2 07-28-2008 07:42 PM
