transatlantic in a catalina 27? - Page 2 - SailNet Community
post #11 of 46 Old 02-18-2011
I own a C27. My particular boat is definitely NOT one I'd take out into the open ocean without doing a lot of work to her. But she's fine for lake/bay/close-in cruising around.
I have little doubt the C27 (well prepped) could take you anywhere if you were careful with the weather. As has been pointed out above - they've done it just fine. And I also personally think it's fine for 2-3 people in a passage situation. It's cozy - but has enough room.
So, as always, it's not really the boat you have to worry about as much as it is you and your crew. Can you do it?
I couldn't at this point. No way.
smackdaddy is offline
post #12 of 46 Old 02-18-2011
travlin-easy's Avatar
Having owned a C-27 and having my a$$ handed to me in the middle of Chesapeake Bay during moderate storms, I would unequivocally say NO! The boat is not an ocean going vessel by any stretch of the imagination. The boat, and crew might make it across the pond, but only if conditions are ideal. Ideal conditions NEVER exist in the real world.
Gary
travlin-easy is offline
post #13 of 46 Old 02-18-2011 Thread Starter
sorry guys i did not read SD's signature but i just did so i will try not to make a a** of myself so ok i have a C27 but i could sell it and buy something else! are the boats in John Vigor's 20 Small Sailboats to Take You Anywhere a credible source? i'm looking for something around the 10,000 range if i do sell it. i say 10,000 because i'm thinking i will need about another 10,000 to outfit it to take on the task! also if need be i might be able to pull another 5,000 to fix it up or buy something in better shape!
thatirishguy is offline
post #14 of 46 Old 02-18-2011 Thread Starter
also i have about 4 years sailing exp. i have faith in me being able to do it but the crew have about a day before we go they will have about 9 months. so it would have to be something i could handle on my own
post #15 of 46 Old 02-18-2011
MikeinLA's Avatar
Where's that popcorn smiley when you really really need it?
Mike
MikeinLA is offline
post #16 of 46 Old 02-18-2011
I'd point out that the Catalina 27 is one of the 20 boats in John's book
sailingdog is offline
post #17 of 46 Old 02-18-2011
You could do this in the worst boat possible and make it. Also, you could sail the best possible boat and fail.
There is always the element of luck.
I would want the best possible elements in my favor. A cat 27 is not a favorable boat.
omaho5 is offline
post #18 of 46 Old 02-18-2011
mitiempo's Avatar
Yes, luck is a factor but I believe that you really create your own luck to a great extent.
I think a Catalina 27 has to be modified extensively to consider the trip.
Bulkheads are not glassed in - constant wracking in seas will loosen their fastenings.
As posted above all deck fittings need solid backing plates.
The main hatch amd companionway are way too large. a proper companionway has parallel sides and there is a proper bridgedeck. The sliding hatch is not large. See below. The second pic is what you want for offshore use.
Can the design of the hull and rig do this - yes, in the right hands.
Brian
mitiempo is offline
post #19 of 46 Old 02-19-2011
Mirage 29
sailjunkie's Avatar
Originally Posted by LauderBoy View Post
But I think 2-3 people crammed into a 27ft boat for 30 days sounds less than wonderful.
Well said. We sailed C27's in our sailing co-op, from 1996 to 2009 when we bought our own boat. If you have the wrong 2-3 people, a weekend can seem like an eternity. Using SD's estimate of 30 days? You may not be friends by the end of the voyage!
I'd like to thank SD and some of the others for identifying who did the C27 circumnavigation. However, at the end of the day, just because crossing the Atlantic in a C27 is possible doesn't mean that it is a good idea.
Mark
S/V Avatar
Mirage 29'
Port Moody, BC
It's not my fault they named a movie after our boat
sailjunkie is offline
post #20 of 46 Old 02-19-2011
CrazyRu's Avatar
if you search the web, you will find the list of modifications around the world Catalina 27 had. The owner basically rebuilt the boat from inside out, including reinforcements, backing plates, new companionway, etc.
I sailed Catalina 27 in ocean for a few days, and it is most definitely not ocean going vessel.
CR
s/v NEMO - Freedom 28 Cat Ketch, centerboard
CrazyRu is offline
Transatlantic with eight kids GoodOldBoat Good Old Boat 7 05-23-2015 05:41 PM
Crew Available for TransAtlantic (1) HeadingEast2 Crew Wanted/Available 0 12-14-2005 01:49 PM
Looking for transatlantic (April) newuser Crew Wanted/Available 0 12-21-2002 05:23 PM
So You Want to Go Transatlantic? Dobbs Davis Cruising Articles 0 05-01-2002 08:00 PM
TransAtlantic in 2003 Colm1 Crew Wanted/Available 3 02-14-2002 05:36 PM
