Old 02-23-2011
genesis3174 is on a distinguished road
davit mounted solar pannel system
I am currently designing a davit mounted solar pannel system and would appreciate any input from the group. I have Ocean Marine System tubual stainless davits with double connecting bar. I would like to mount three 80W solar pannels transversely that are stacked over the davits when under way. At anchorage, the two top pannels would pivot outward-one port and one starboard and have the capacity to tilt to maximize the angle to the sun. I am located on northern Chesepeake Bay area.
Any suggestions on where I can find stainless mounting hardware to accomplish this. Thanks.
Gary (New Member)
Nauticat 33, Genesis
Old 02-23-2011
jrd22's Avatar
Courtney the Dancer
Kato makes a panel mount for their davits, not sure if you could adapt it to fit your's or not.
Welcome to SN Genesis!
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
Old 02-23-2011
sawingknots's Avatar
sawingknots is on a distinguished road
solar panels
i'm in the process of mounting 3 panels on the stern rail of my boat[py26] i haven't found any brackets either so i'm going to make some using 3 wooden blocks "31/2 long "3 inches wide and about "3 thick,i'll bore a "1 inch hole across the middle at the same angle as the rail then i'll cut them into halves leaving a halve hole on each piece.i'll bolt them back together on the rail with stainless bolts,i think i can then adjust these brackets so the panels can be raised up or lowered when needed,i'm planing to build the rest of the framework out of 3/4 by "3 red cedar slats[red cedar is very light and resists rot]the blocks i'm thinking of some tough wood [maybe elm] elm rots easily so i'll keep them oiled often,i'll use some sort of brace legs that can be adjusted lengthwise lol i haven't gotten that far yet.i hope this is of some help to you,if not just disregard no harm no foul.sawingknots
Old 02-23-2011
btw i'm very cheap [stingy]
Old 02-23-2011
QuickMick's Avatar
QuickMick is on a distinguished road
but your avatar looks so giving and fancy free!
How inappropriate to call this planet Earth when it is quite clearly Ocean ~ Arthur C. Clarke
Quinn McColly
Yacht Broker
Old 02-23-2011
lol that was on a good day,usually i look downright sweet
Old 02-23-2011
carl762's Avatar
Sundance 23
carl762 is on a distinguished road
Lol.
Water is Life
Old 02-23-2011
What diameter tubing are the davits made from? You will probably have to mount the outboard panels to a frame and then have the frame pivot. Can you post a photo of the davits, since that would make it easier to give you advice on how to design a panel mounting setup for them.
simple system to do most of wind/solar/alternator/shore to house/starting/dump + more Bene505 Electrical Systems 30 02-24-2009 04:21 PM
Davit and solar panels Oh My Freesail99 Gear & Maintenance 10 03-27-2008 11:46 AM
Arch Davit System for 38cc-Can your dinghy be too big? FortAwesomeIII Gear & Maintenance 23 12-31-2007 01:13 PM
Solar Panel Mounting On A Davit Freesail99 Gear & Maintenance 8 08-14-2007 02:22 PM
New davit with wind and solar charging dsbentley Gear & Maintenance 17 08-03-2006 10:33 AM
