Slip preference? - Page 2 - SailNet Community
post #11 of 28 Old 02-25-2011
Given the exposure and the prevailing winds, a T at the lower marina would be a nightmare.
sailingdog is offline
post #12 of 28 Old 02-25-2011
fallard's Avatar
Unless you want to build a relationship with the smaller yard, you might consider the Brewers yard (looks like Barrington, RI) and save some $ (unless you've already signed the contract.)
Given the predominant SW breeze and the heavy boat traffic, you will find your boat pinned against the face dock and will want to guard against fender burn. I'd go for the slip, since you won't normally have much of a cross wind. If they've dredged recently, you should know whether your draft is a problem.
fallard is online now
post #13 of 28 Old 02-25-2011
pdqaltair's Avatar
Go between pilings.
1. Getting off a tee in an on-shore wind is not easier. Doable, but not easier.
2. Rubbing on fenders 24/7/365 is a minus.
3. Wakes get old.
4. Ice in the winter amplifies the above.
5. Docking in your home slip with pre-tied lines and fenders where you need them is easy.
As cat sailor that gets a lot of t-docks when cruising, I'm always glad to get home, where I can tie-up between pilings.
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
post #14 of 28 Old 02-25-2011
Brewers nickels and dimes you for every expense from what I've seen. They have pretty good facilities with a lot of amenities, but you end up paying for it.
post #15 of 28 Old 02-25-2011
Tim R.'s Avatar
We live aboard now Ed and I can tell you that protection is the key. You will sleep better at night. Fetch and wave action are one thing but what about loose boats, docks and other debris that could collide with your boat in a storm.
And the longer walk is a pro. Ask your doctor;-)
Tim R.
Our Carina is for sale
1997 Caliber 40LRC
Tim R. is offline
post #16 of 28 Old 02-26-2011
Lot of good advice here. The first year with a new to us boat (one boat past), the marina did not have a space for us so we spent quite a bit of time on the T. As other's have said, when the wind blows directly onto the T, it pushes you on, and crushes the fenders. You have no way to tie off (short of an anchor set which may not be possible if their is boat traffic). I spent a couple of storms tending fenders. Get a slip if you can. Also nice for cleaning topsides, etc.
capecodda is online now
post #17 of 28 Old 02-26-2011
MikeinLA's Avatar
I would vote for the slip. I have had severe weather conditions develop while out sailing that would have made it difficult to dock on the T upon returning home, whereas if you can get the pointy end into the slip, the rest will follow. Also, where I am in Marina del Rey, you wouldn't believe the number of end tie boats that get hit. "Hey guys, let's try tacking up the channel". And no, they don't leave a note.
Mike
MikeinLA is offline
post #18 of 28 Old 02-26-2011
Having had a fender jump the dock overnight at a highly exposed marina, I would sooner take a mooring ball than that risk again. I can't really tell how exposed to fetch you would be at the T-dock, but it surely looks like a candidate. At the least, I would attach permanent fenders to the dock if you take it. There are some tips on how to do that so they don't just become ripped off or cause damage, if you are interested.
Jeanneau 54DS
Minnewaska is offline
post #19 of 28 Old 02-26-2011
fallard's Avatar
If you attach permanent fenders that are intended to provide real protection for your boat, use boat fenders, like Taylor Big B or equivalent. I use 6 of these fenders (20" size) strung out horizontally over a total distance of 14 ft or so, with dock attachments at each end of the fenders and have had good luck over the past 5-6 years. I have 23' and 35' boats on opposite sides of the same floating dock. That said, I am in a protected area where wakes and seas are rarely a problem.
I don't have tie-off piles. If the winds pick up to 50+ knots, I'll put out larger fenders over the side of the boat(s) in case the installed fenders get squashed, but then you need to be careful that the additional fenders don't jump out of place. If 60 kts or more is predicted, I would move the boats to a storm mooring.
post #20 of 28 Old 02-27-2011
I agree and a couple of more points.
Oversize the fenders, if possible.
Use fenders that accept a line through the middle so that they will rotate as the boat move up and down against them.
Never allow them to be in permanent contact with the water.
Mounting hardware should be SS and oversized as well.
Jeanneau 54DS
Bilge pump preference Shortman Gear & Maintenance 16 03-18-2010 12:49 PM
Deck Paint Brand/Preference and Tips brianontheroad Gear & Maintenance 10 07-21-2008 01:31 PM
Main VHF Preference? MedSailor Gear & Maintenance 33 05-06-2008 04:44 PM
Extended Stay in the Keys - What's Your Preference? PBzeer Cruising & Liveaboard Forum 46 12-22-2007 07:15 PM
Slip Sub-Lease via Slip Renter KeelHaulin General Discussion (sailing related) 4 06-26-2007 12:50 AM
