Slip preference? - Page 3 - SailNet Community
post #21 of 28 Old 02-27-2011
The mounting hardware can be galvanized steel, which is probably better for dock hardware than stainless. No need for the expense of stainless steel hardware.
sailingdog is offline
post #22 of 28 Old 02-27-2011
That's fair. Just don't use hardware store steel stuff.
Jeanneau 54DS
Minnewaska is offline
post #23 of 28 Old 03-01-2011
Brewers nickels and dimes you for every expense from what I've seen. They have pretty good facilities with a lot of amenities, but you end up paying for it.
SD, something came up today that made me think of this comment, so I came back looking for it.
What have you seen specifically? All charge for the slip, electrical usage (in some way) and fuel, so what nickle and dime stuff do you see beyond the usual?
Jeanneau 54DS
post #24 of 28 Old 03-01-2011
If you bring an external contractor in to work on your boat, they charge the guy for the "privilege" to work on their property, which raises the amount he has to charge you. IIRC, you generally can't do almost any work on your own boat at most of them. The list goes on...
At my marina, if you want to bring in an external contractor to do work on your boat, there's no fee or surcharge, and the only requirements the marina has is that they have proof of insurance and that they clean up after themselves.
If you want to do the work yourself on the boat, my marina is pretty good about getting you setup in a space where you can work uninterrupted, and if you have a slip or a mooring with them, they don't charge you outrageous yard fees to keep your boat on the hard while doing the work.
post #25 of 28 Old 03-01-2011 Thread Starter
Learning the HARD way...
eherlihy's Avatar
I KNOW that they charge contractors to enter their yard. I got an estimate for having my boat soda blasted, and the guy said that he had to add an additional ~$300 to cover his costs of working in a Brewer yard. IIRC it was ~$1700 for them to soda blast a 35' boat in a Brewer yard.
However, Brewer will allow you to work on your own boat, and they'll gladly pick up on a project that the owner has gotten over his head on.
They really squeeze the boats in next to each other while on the hard though.
I do not have a boat in front or behind me in my current yard. I can drive right up to my boat. At the Brewer yard the boats are butted right up against each other, at least 3 deep. I would hate to think of the consequences of a fire...
eherlihy is offline
post #26 of 28 Old 03-01-2011
Mark ups are the norm in my experience, glad to hear you found an exception. I don't like them, but I sort of understand that the marina is paying the expense of having a waterfront workshop that the guy who shows up with a van doesn't have to incur. Most marinas rely upon revenue from services other than slip fees to pay for the joint.
Can't imagine how they could keep you from working on your own boat in the slip, but I have experienced restrictions in several marinas over sanding or painting that causes environ issues. Thanks for the feedback.
Jeanneau 54DS
post #27 of 28 Old 03-01-2011
Well, the problem I have with the marina charging the contractor a fee is that the marina is already being paid for that yard space, since the boat owner is paying for the space. Their charging a fee to the contractor is essentially double dipping as far as I am concerned.
If the marina wants to offer services, then they should offer them at a competitive price with comparable quality. The reason people don't use a marina's services is usually either that they're too expensive compared to their competitors or the work is sub-par compared to their competitors or both.
post #28 of 28 Old 03-03-2011
Don't get me started on bad marina technicians. I've had more than my fair share of nightmares. I would be happy to find one that doesn't simply lie about how much time it takes to complete work. At the end of last season, I was charged 3 hrs of labor to pour 5 gallons of antifreeze down the main engine strainer. Nothing more to the job.... go onboard, open the panel, screw top of strainer off, pour in AF as engine is started, shut engine off. I was just charged 12 hrs of labor by the same yard to replace a cutlass bearing and clean a max prop.
That said, I don't think too many marinas can survive on slip/mooring fees alone. Therefore, if they don't get additional work, those fees would have to increase.
If there were one reliable, honest and friendly boat yard, they could charge whatever they like for an hourly wage and boats would be lined up down the entire bay to go there.
Jeanneau 54DS
Bilge pump preference Shortman Gear & Maintenance 16 03-18-2010 12:49 PM
Deck Paint Brand/Preference and Tips brianontheroad Gear & Maintenance 10 07-21-2008 01:31 PM
Main VHF Preference? MedSailor Gear & Maintenance 33 05-06-2008 04:44 PM
Extended Stay in the Keys - What's Your Preference? PBzeer Cruising & Liveaboard Forum 46 12-22-2007 07:15 PM
Slip Sub-Lease via Slip Renter KeelHaulin General Discussion (sailing related) 4 06-26-2007 12:50 AM
