02-27-2011
Cat boats in general are not fast boats. They're very beamy and have a lot of wetted surface area. The Horizon cat is actually based on a Herreshoff (Halsey IIRC) design. I've sailed along side quite a few of them as Buzzards Bay is my home waters and they're out in conditions that send a lot of other boats running for harbors.
That said, I haven't been on a catboat in 20+ years, having sailed them when I was in college, as a friend owned one back then. One of the nicest catboats I've seen was a custom Arey's Pond built catboat called The Stray, which hails from Orleans, MA, and I met down in St. Augustine last spring.
The in-board diesel is definitely the way to go. A good book for you to read is Catboat Summers, which is about sailing various catboats on these waters.
BTW, it probably isn't necessary to get a catboat for these waters. The Nonesuch 26 isn't that deep a draft vessel and should be fine. You won't have the option of winter storage at your home on a trailer, like you might with a catboat, but most catboats aren't legally trailerable, since they're too wide.
