Weird 'severe' vibration - Page 2 - SailNet Community
post #11 of 29 Old 02-28-2011 Thread Starter
Another question - what is this 'gland' exactly called?
SpcAlan1 is offline
post #12 of 29 Old 02-28-2011
RichH's Avatar
The 'gland' is the component that is forced against the packing. The gland would be identified by all the components within dimension "S" on this 'large' stuffing box. http://www.pacificmarine.net/pdf%20f...%20-%20PMI.pdf
RichH is offline
post #13 of 29 Old 02-28-2011
Needing Apehanger Helm
HDChopper's Avatar
Thanks RichH for the link ....
There is no right way to do the wrong thing
HDChopper is offline
post #14 of 29 Old 03-01-2011 Thread Starter
Thanks guys for the help.
I will take a photo the next time I go out to the boat for your entertainment.
SpcAlan1 is offline
post #15 of 29 Old 03-01-2011
RichH's Avatar
Get, borrow, etc, a "dial indicator" (micrometer) and take measurement of 'shaft run-out' while (hand) rotating the shaft - with tight gland and with loose gland. Use the instrument on the shaft and also ON the stuffing box.
examples: Fowler FOW72-520-199 Dial Indicator and Magnetic Base Set - Black
RichH is offline
post #16 of 29 Old 03-01-2011 Thread Starter
hand rotating?
I had to use 2 wrenches to 'loosen' it to get it to drip.
SpcAlan1 is offline
post #17 of 29 Old 03-01-2011
Senior Slacker
SlowButSteady's Avatar
I'll bet the cutlass bearing is shot, in addition to an alignment problem.
Never forget them. Do something to prevent it from happening again.
Charlotte Bacon, Daniel Barden, Rachel Davino, Olivia Josephine Gay, Ana M. Marquez-Greene, Dylan Hockley, Dawn Hochsprung, Madeleine F. Hsu, Catherine V. Hubbard, Chase Kowalski, Jesse Lewis, James Mattioli , Grace McDonnell, Anne Marie Murphy, Emilie Parker, Jack Pinto, Noah Pozner, Caroline Previdi, Jessica Rekos, Avielle Richman, Lauren Rousseau, Mary Sherlach, Victoria Soto, Benjamin Wheeler, Allison N. Wyatt
SlowButSteady is offline
post #18 of 29 Old 03-01-2011
Originally Posted by SpcAlan1 View Post
hand rotating?
He means rotating the prop shaft by hand... you're looking for 'run out' or a wobble in the shaft as it turns. You can usually grip the coupling at the back of the gearbox and get enough leverage to turn the shaft.
Faster is online now
post #19 of 29 Old 03-01-2011
I suspect the same. If it wasn't the original cause, it may have been worn from the excessive vibration or misalignment.
Jeanneau 54DS
Minnewaska is offline
post #20 of 29 Old 03-01-2011
RichH's Avatar
hand rotating?
Hand rotate the SHAFT when using a dial indicator.
RichH is offline
To me, it's just weird... Dannyre General Discussion (sailing related) 22 12-08-2010 05:01 PM
weird engine noise jr438234606 Gear & Maintenance 35 12-29-2008 06:30 PM
Does anyone recognise this weird keel? Sasha_V General Discussion (sailing related) 10 02-24-2006 07:05 AM
