Galley idea.. a bit of input is hoped for - Page 5 - SailNet Community
post #41 of 129 Old 03-28-2011
Once known as Hartley18
Classic30's Avatar
Dock
I've been following at a distance. Looking good, Graeme!
I know this is a little late, but for what it's worth:
Originally Posted by GraemeInCanada View Post
Thanks jones, got the paper towels moved and I like the idea for the cups hanger. As I look at it, won't they clank around a lot? Am I missing something there? a piece of wood between each cup perhaps?
In practice, no, they won't clank around - not if there's at least a little space between them and, to my eye, what you've drawn seems about right - because they all move together.
I thought about a folding countertop space but I'm not sure I need it anymore. The area above the water tank will also have a removable/hinge based piece, so that will help. I'll have to get that in the next render.
Our boat has a small folding countertop over the end of the settee, hinged off the right-hand bulkhead and held up by a cord to a hook on the overhead. It normally stows down out of the way, but you might find it handy whilst you're using the stove.
In any case, it wouldn't affect your design and could be fitted anytime.
Classic30 is offline
post #42 of 129 Old 03-28-2011 Thread Starter
Thanks!
That's interesting about the cups.. that really works? They won't clank around at all? I'll head to the dollar store for some test cups when I'm done.
Good idea on the fold down counter. When I'm further along in the refit I'll post pictures again to see how it will go.
My blog on boat related stuff:
GraemeInCanada is offline
post #43 of 129 Old 03-28-2011
Classic30's Avatar
Dock
Thanks!
Graeme, give it a try, but the way you showed them in your rendering (very impressive, BTW), so long as they can't hit the side walls, I'd be surprised if they did. Unlike other forms of transport, larger yachts tend to move around relatively slowly and don't jerk - thus clanging cups together. Some test cups hung from the deckhead will tell you one way or the other.
I look forward to your updates. Refurbishing our galley is on my list of things to do..
post #44 of 129 Old 03-28-2011
tdw
Super Fuzzy Moderator
tdw's Avatar
Graeme,
My apologies if its been covered and I missed it but why a non gimballed stove ? Even at anchor I cannot conceive of non gimballed. Gives me the willies just to think about .
Otherwise I have to say its looking pretty good, given what you had to work with.
Andrew B (Mal÷ 39 Classic)
ôLife is a trick, and you get one chance to learn it.ö
― Terry Pratchett.
tdw is online now
post #45 of 129 Old 03-29-2011 Thread Starter
Excellent question, one that hasn't even been brought up yet. I did think of it though.
I decided not to go with a gimballed stove due to lack of need. I never cook while underway and when at anchor I'm usually in a secluded area. The only times I've used the stove and it's been rocky is when I've been sitting right there keeping a sharp eye on things. I get it though, there are times when some powerboater is going to go by with his huge hull pushing mounds of water out of the way which will rock my boat like crazy all of a sudden if taken on the beam. But it's rare indeed and wasn't worth the extra cost at this time.
Thanks for the compliments. I'm just readying another update here actually. Lots of progress being made.
post #46 of 129 Old 03-29-2011
The stove must have fiddles and pot holders.... mandatory. Boiling water is as dangerous as a fire itself to your skin.
Jeanneau 54DS
Minnewaska is offline
post #47 of 129 Old 03-30-2011 Thread Starter
Absolutely. Those are on the "to buy" list.
Just got the vinyl fabric today for the ceiling, got some great deals.. also got the fiberglass, epoxy and a couple of tools for fiberglassing that I've been borrowing from a friend up to this point. That stuff is expensive..
Made good progress on the mockup and also managed to pick up a bit more mahogany for the trim etc. It's late now and I'm pretty tired from the day but I'll post pics tomorrow and an update on progress.
post #48 of 129 Old 03-30-2011
Ilenart's Avatar
Graeme,
great post, really like the 3D software. Sorry to come in late with suggestions however another option is not to use doors but to have either a strip of wood or material secured with rope to hold pots & pans, cups, etc. Below is what I mean; nothing has come loose. The stove is also a gimbled alcohol stove.
Ilenart
Photobucket
Ilenart is offline
post #49 of 129 Old 03-30-2011 Thread Starter
That's a great suggestion! Thanks for showing a pic too, that helps a lot.
On with an update then:
Now that my templates were done I needed to get on with making a mockup before I start cutting up expensive plywood and not quite getting it right. I'm reasonably picky about stuff fitting and all that and would like to get this right the first time. Here I have a picture of each piece cut out and ready to be put on a basic frame:
In the middle piece I've drawn out where the sink and stove will go and where the cooler will be. Hard to tell in such a small pic, but they're worked out on that piece. Each side piece is cut so that it matches the top in width and is the right height. Measure 5 times, cut once, even cheap plywood like that.
After building a basic frame with 1x2 I screwed each piece on and tossed the sink and stove in place to see how it would look:
Not bad I think. I'm looking forward to getting this down to the boat and seeing if it fits in the companion way for one, but then in place and up to the shape of the hull. I have to cut out the front part or I'll never see if the forward side fits right (that is if the hull side fits correctly). That will help the next item that I want to work on, which are the doors for the front to get under the stove and sink. I've managed to get some nice mahogany for that so I'm looking forward to get on with that.
Next major stuff is to do a thorough clean up of the hull, some fiberglassing to allow me to attach the new vinyl covered plywood and paint on top of all that with some kind of insulation that has yet to be decided on. Lots to do. I'll post more soon. Of course any pointers or suggestions are more than welcome.
post #50 of 129 Old 03-30-2011
Irrationally Exuberant
I came into this late, but it's cool to follow your project from early concept to your real work. Nice job! I hope you'll keep posting.
Tom
Tom K
2000 Beneteau 331
Northern Chesapeake Bay
arf145 is offline
C&C 38 need input CliffR Boat Review and Purchase Forum 9 08-05-2010 12:44 AM
Need input on C25 Kids4sail General Discussion (sailing related) 2 06-10-2010 05:42 PM
Looking for daysailer input Randolph Bertin Boat Review and Purchase Forum 3 09-01-2004 09:05 AM
Pearson 33 K/CB input please garyp Boat Review and Purchase Forum 3 03-16-2004 05:42 PM
Input from Cruisers please. Speedy50 Cruising & Liveaboard Forum 13 10-16-2003 01:12 PM
