Propane canister from Hell - Page 2 - SailNet Community
post #11 of 51 Old 03-09-2011
One could always keep a torch onboard. If the canister leaks when you remove it, just screw on the torch. You don't have to waste the propane that way.
If you are still worried about it you can lash it on deck where even if it leaks the fumes won't accumulate.
knothead is offline
post #12 of 51 Old 03-09-2011
the canister wasn't evil it was Neptune sending you a message about throwing things overboard
cruisingdream is offline
post #13 of 51 Old 03-09-2011
Why would you get rep points for recommending a dangerous procedure........
The referenced procedure above is to buy and install the safety caps. Seems you missed that point.
Yes, we now have anecdotal blog evidence that suggests these leak. Still not authoritative. Nevertheless, I have found a solution with the caps, implemented it myself and others are following it in the name of safety. Why still the grudge?
p.s. I was kidding about the rep points, which is the purpose of the big smiley afterward.
Jeanneau 54DS
Minnewaska is offline
post #14 of 51 Old 03-09-2011
Somewhat Senior Member
mgmhead's Avatar
Maybe I'm just too darn simple but I store my 1# propane bottles in the anchor locker, which drains overboard. Am I missing something?
s/v Rhythm
Catalina 387 #29
Rock Hall, MD
mgmhead is offline
post #15 of 51 Old 03-09-2011
Pearson 303
SVCarolena's Avatar
No, you have it right. I've heard of anchor locker, PVC pipe holder attached to the rail or, as we do, keep it in the bbq grill which is attached to the stern rail - the key being to keep it outside the boat in the event of a leak. I ordered the caps because it looks like some good secondary insurance, plus will prevent the cannister from emptying out before the next bbq! I wish we had propane installed, but we don't, alcohol stove and Dickinson bbq on the rail with the portable tanks.
SVCarolena is offline
post #16 of 51 Old 03-09-2011
F15EWSO's Avatar
Uhhh no. 1Lb canister, partially used cooking dinner. Leaking into the atmosphere (read as immediate dispersal), no source of ignition.....so where is the anxiety? How much trouble do we have lighting the grill when there is some wind? And that's trying to ignite it! I would have looked at the thing, cursed it for lost fuel and $$ and as mentioned by someone else put it on the grill, re-ignite and clean it.
F15E_WSO + 1
Deale Md, to Caribbean Oct 2012-Aug 2013
Boat Type Irwin 43 Mk III Center Cockpit--Sold it
Boat Yr, 1989
Boat Length 43'
F15EWSO is offline
post #17 of 51 Old 03-09-2011
bljones's Avatar
Oh hell, in situations like this, my usual solution starts with the incantation "Hold my beer..."
It's 5 o'clock somewhere:
bljones is offline
post #18 of 51 Old 03-09-2011
BBrut's Avatar
The best southern way to remedy this situation is to toss the sucker overboard, grab your trust AK-47 or M-16 and blow the sinister little can to HE--! Gotta keep the gun sighted in for boarders.hehehe
BBrut is offline
post #19 of 51 Old 03-09-2011
chef2sail's Avatar
If it looks like a duck...walks like a duck...quacks like a duck...tastes like a duck..I guess anectdotally it may only probabaly be a duck unless of course you find its picture in a journal of Ornithology. Then of course thats authoritative...but both are correct.. its a duck **:**)
No grudge at all...didnt miss your cap point either. Band-aid solutions just do not appeal to me. I prefer to fix things the correct way. Would hate to see someone try a band aid solution that really did not work in the long run.
Let BBQ together this summer when we are up in the area unless you get down to the Chesapeake first..
Quack,,,Quack
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #20 of 51 Old 03-09-2011
......Quack,,,Quack
The only duck I see, is the stubborn one that won't accept a solution other than their own. Somehow, when you screw a valve closed, that seems smarter than screwing a cap on a bottle. Give a little, its liberating.
I'm also certain that I have better knife and saute skills than you as well.
Jeanneau 54DS
CNG Canister search - Great Lakes dergon Gear & Maintenance 4 02-15-2011 03:41 PM
Hell Gate dlewis812 General Discussion (sailing related) 6 04-16-2010 03:12 PM
Hell fittings? nauticalrich Gear & Maintenance 1 06-17-2003 07:23 AM
