Old 03-09-2011
willysail is on a distinguished road
Soda Blasting Hulls
Hi everyone, I was wondering if anyone had any experience with “Soda Blasting” the bottom of there hull. I have some repairs that I need to do and after talking to several people the consensus is to soda blast the hull below the waterline. I wanted to know if this is a standard procedure and would it damage the gel-coat. It would be nice to get all the years of residual bottom paint off.
Old 03-09-2011
treilley's Avatar
treilley is on a distinguished road
Soda blasting works well if done by a professional.
I stripped my previous boat's hull(35 ft.) with walnut shell blasting. Rented a compressor and blasting unit locally and bought 6 50lb bags of walnut shells. 1/2 day and it was done. Total cost abour $450.
Tim R.
Living aboard in Portland, Maine
1997 Caliber 40LRC
and
Old 03-09-2011
Treilley,
Someone told me that any kind of hard abrasive would damage the gel-coat finish.
Old 03-09-2011
sawingknots's Avatar
sawingknots is on a distinguished road
all i know is its expensive but does a good job depending on the operator,chopped up corn cobs work well too
Old 03-09-2011
will this pit the surface of the boat
Old 03-09-2011
Barquito's Avatar
Barquito
Barquito is on a distinguished road
I was told by my surveyor I should do this too. Possibly consider doing a barrier coat after media blasting. This would help cover any dings from when whole walnuts and corn cobs chip the bottom of your boat so that it looks like a golf ball. (actually maybe a golfball finish on the bottom would be faster?)
My question is: How much of a mess does it make? My boat is on gravel in a boat yard. Will they be pissed if there is 300 lbs of walnuts under my boat?
Old 03-09-2011
tommays's Avatar
This is one of those it really depends on whose driving and wear you live as on Long Island at this point when they do bridge work its full on tent with LARGE vacuum units kind of like asbestos removal
I am really not sure what there doing with the leftovers BUT its all HAZ-MAT and i would think just flying under the radar right now
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 03-09-2011
hellosailor's Avatar
Soda blasting is just media blasting, using baking soda as the medium. Corn cob, crushed walnut shells, sand, are also used as media. Each has a different amount of abrasiveness and a different cost, and the reason for soda blasting is that it is one of the gentlest ones. it will strip the paint without harming the gelboat--if used at the right pressure, as any pro should be able to do it.
Yes this is a common way to do the job, and a safe way. Your alternative is chemical strippers ("rinse, lather, repeat") or other conventional abrasives. I think soda blasting is probably as cheap and fast as anything else, and if you can arrange your schedule to fit the guy's slack time, or get more than one boat for them to work on while they're at the yard, you can probably trim the cost down a little too.
It can even clean old paint off PLASTIC without marrring the surface, so if there's anything else on board that needs "unpainting"....
Old 03-09-2011
BarryL's Avatar
BarryL is on a distinguished road
soda blast
Hello
I had my boat soda blasted in 2008 and I was VERY happy with the results.
If you want to see some pics of before / after soda blasting, go here:
http://www.sailnet.com/forums/gear-m...done-test.html
Barry
Barry Lenoble
Day To Remember, 1986 O'day 35
Mt. Sinai, NY
Old 03-09-2011
tommays's Avatar
Barry
Who is the trusted contractor on Long Island
Tommays
Northport NY
Sandblasting vs. Soda blasting thereIwas Gear & Maintenance 11 06-27-2010 11:22 AM
Soda Blasting Gulfislander Gear & Maintenance 24 05-04-2009 04:47 PM
Soda Blasting cas8100 Gear & Maintenance 4 06-16-2008 01:26 PM
Soda Blasting jrPROC Gear & Maintenance 14 10-14-2007 06:22 PM
