Why they call them "foulies" - Page 2 - SailNet Community
post #11 of 20 Old 03-11-2011
liveincolor's Avatar
Originally Posted by JoeDiver View Post
I guess expensive is relative. I got a big bottle of it for $6 and it's taken me through 3 seasons so far. Can't even get a pack of smokes for $6 in many places these days. I probably have $6 in change in my car, between the glove box, center console and shifter console.....while I like to do my own things and home made concoctions, I do have a limit on expense versus convenience. Just sayin.
Very true. I'm a huge fan of independence and the do-it-yourself attitude. And even though I feel rich, I don't have much money, hehe.
liveincolor is offline
post #12 of 20 Old 03-11-2011
Boasun's Avatar
And here all this time I thought you called them Foulies because you couldn't get them off in time when you really need to sit on the throne.
1600 Ton Master, 2nd Mate Unlimited Tonnage
Maritime Instructor
S/V Rapture
Boasun is offline
post #13 of 20 Old 03-11-2011
jackdale's Avatar
Is the OP discussing foulies or wetsuits. Foulies can just be washed and hung. That also gets the salt out and stops some leaks.
jackdale is offline
post #14 of 20 Old 03-11-2011
Quickstep, you don't say what brand or kind they are, what material they are. The washing care will vary. If there's no care tag that came with them, I would suggest calling the maker, or telling us what they are made of. If they are "plastic" or "breathable water resistant" everything is different.
Odds are the stink can be easily washed out, unless it is the "barf" smell that uncured cheap plastic sometimes gets as it ages. That's forever, the result of the plasticizers leaking out or breaking down.
hellosailor is offline
post #15 of 20 Old 03-11-2011
SERIOUS SAILOR
JoeDiver's Avatar
Originally Posted by hellosailor View Post
.... unless it is the "barf" smell ....
Ahhh, memories of the rain suit issued to me by Uncle Sam....sitting in a cold, wet foxhole smelling like barf.....
1982 Catalina 25 #2897
FK/SR/Traditional
Eagle Mountain Lake, Texas
JoeDiver is offline
post #16 of 20 Old 03-11-2011
Sundance 23
carl762's Avatar
Yes, can't get that smell out of my brain, now that you mention it.
Water is Life
carl762 is offline
post #17 of 20 Old 03-11-2011
flyingwelshman's Avatar
Dammit Jack I'm a Chef not a couturier, but I would think that the micro-organisms that contribute to the foulness of rain gear might be the same ones that give neoprene its 'just-pissed-in-freshness'.
1989 Hunter 30'
Southern Georgian Bay
Visualize the vastness of the oceans; the infinity of the heavens; the fickleness of the wind; the artistry of the craft and the frailty of the sailor. The oneness that may be achieved through the harmony of these things may lead one to enlightenment. - Flying Welshman
flyingwelshman is offline
post #18 of 20 Old 03-11-2011
jackdale's Avatar
You are likely correct.
I am just reluctant to use any chemicals on my foulies.
jackdale is offline
post #19 of 20 Old 03-11-2011
I don't discuss my member
zz4gta's Avatar
For gortex, just follow the directions. I was with a mild detergant that does NOT include a fabric softener. Through in the dryer on low for 30-45 minutes and then spray a bit more Nikiwax on it. They get cleaned about 2-3x a season. The nikiwax smells a bit, but it goes away.
Never use bleach or fabric softener on hi-tech clothing. Even powdered detergant like oxy-clean has a bleaching agent in it. Read the friggin labels.
Merit 25 # 764 "Audrey"
zz4gta is offline
post #20 of 20 Old 03-11-2011
Seconding the freezer suggestion.
Seriously, it works as well as any of the other methods mentioned so far, without compromising the waterproofing. If it's looking dirty as well as smelling it you can always freeze for a day and then wash it out in plain, hot water.
The smell is caused by bacteria that are entirely killed off by the freezer because the moisture inside the bacteria crystalises and tears the bacteria's membrane.
limeyrock is offline
"Seacock" vs. "ballcock" or "ball valve?" SEMIJim Gear & Maintenance 18 09-02-2013 05:31 PM
"Oily Pollution" and "MARPOL Trash" Placards? SEMIJim Gear & Maintenance 16 11-15-2011 09:39 PM
C270 Main Sail "stack Pack", Quick Cover", "lazy Bag" Install randy22556 Catalina 1 02-28-2007 11:53 AM
36' yawl "Wild Call" jrh69ca General Discussion (sailing related) 12 08-10-2006 07:32 AM
