03-12-2011
Senior Slacker
That type of boat is perfectly capable of such a trip. I would suggest three things: have the sails/rigging set up as if you were going on a blue-water crossing, rather than a coastal cruise (i.e., be ready for anything); ALWAYS be prepared to hightail it for the nearest safe harbor, and wait out the weather for as long as it takes (even if that means losing a couple of hundred miles of "progress", and a week or two of time); have a good strong engine and plenty of fuel. Summer is by far the best bet for such a trip. Even late spring can be nasty. North of Pt. Conception the wind will almost always be on your nose, except when it's flat calm. So you'll either be close hauled or motoring most of the time. Along this coast, if you do catch a southerly breeze it will almost certainly be associated with low-pressure system, so it usually means it's time to find a place to hide from the weather.
On the other hand, if you allow yourself plenty of time, and have a well prepared boat, it can be a great trip, and will undoubtedly provide you and your crew with plenty of stories with which to scare others ("There I was...").
