Cabin Top Traveler and Main Sheet - Page 2 - SailNet Community
post #11 of 49 Old 03-14-2011
JaredC's Avatar
Harken sells retrofit traveler kits, including tracks that can span open space such as the cockpit...
JaredC is offline
post #12 of 49 Old 03-14-2011
Originally Posted by T34C View Post
Fast/Yeah- I'm guessing the issue isn't in the functionality of the current system but more likely that he can't REACH the current system from the helm. I have the same issue with mine in that I can't get to the mainsheet without climbing around the wheel. You can fix it by running the sheet further outboard (than Fasters diagram) and bringing the sheet back to a secondary winch further aft in the cockpit.
Probably correct T34, but it sounds like he's got the cleat on the block at the traveler car, which makes things even more difficult, esp shorthanded. Inverting the cleat might help, but might also jeopardize an easy release.
Running the tail forward and back as you suggest will help, double end it and you've got the German system. It's certainly not practical to sail holding the sheet by hand all the time on a 30 footer; in certain conditions it's a guaranteed rope burn scenario.
I think any mainsheet system that relies on a winch is generally going to be slow to adjust/trim.
Faster is offline
post #13 of 49 Old 03-14-2011
One of None
deniseO30's Avatar
So glad I did not move the Traveler to the cabin top on my boat.. the only thing it seems to help is to de-clutter of the companion way step not to mention cabin top travs are so very short in travel.no wonder the main sheet is needed more.
My last project!
deniseO30 is offline
post #14 of 49 Old 03-14-2011
Thanks Courtney.
I think you might be jumping to conclusions there. All boats are different. My boat originally had a traveler in the cockpit. It was changed to mid boom sheeting and moved to the coachroof where the traveler is now 3x longer than the original.
hunter Legend 37 Semper Paratus
Formerly - Tartan 34C Yawl
T34C is offline
post #15 of 49 Old 03-14-2011
chef2sail's Avatar
I am with you T34C. Since I no longer race I prefer it on the coachtop. It alllows for a binim and dodger combo...full enclosure. The track is longer as you said. No guest is accident tripping it or tripping over it in the cockpit. Like you we have led it back to ther helm area via a side block for me when I single hand. Every one has different needs here.
Dave
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #16 of 49 Old 03-15-2011 Thread Starter
Yes, the problem is that I cannot reach it.
I think the 'winch' idea would be tough if the wind picks up - would take too long to adjust.
I am going to do some research and see what i can do.
SpcAlan1 is offline
post #17 of 49 Old 03-15-2011
One of None
deniseO30's Avatar
Spc.. pictures would really help everyone wanting share some ideas.. How to Use a Traveler – Using a Mainsheet Traveler
I've crewed a few times on boats that had cabin top travelers. The Loads on them are immense during any kind of stronger winds. The winch is needed to even move the car windward on some!
My last project!
post #18 of 49 Old 03-15-2011
One of None
deniseO30's Avatar
these come in very handy for all kinds of things. the traveler lines and jib sheets. I guess the lines could be even longer to control a cabin top set up. but the lines would be a mess for passengers.
And of course this is what everyone hates, I hated the location also but have realized when single handing it's easy to work the traveler.
My last project!
post #19 of 49 Old 03-15-2011 Thread Starter
I just posted a photo of my traveler.
Go to member galleries.
SpcAlan1 is offline
post #20 of 49 Old 03-15-2011
One of None
deniseO30's Avatar
Lovely boat Alan!
My last project!
EASYCAR main sheet traveler - The quest pedcab Gear & Maintenance 0 05-24-2010 03:26 AM
O"day 28 main sheet FourSeasMilford O'Day 2 09-11-2009 09:13 PM
How loose is your main sheet while raising the main? legarots General Discussion (sailing related) 33 06-24-2009 04:26 AM
moving the main sheet freddyray Gear & Maintenance 3 05-15-2009 09:02 AM
Main traveler moved to cabin top GaryT Gear & Maintenance 2 01-08-2007 04:14 PM
