Blogs
User Name
Old 02-07-2001
NYSailaway NYSailaway is offline
NYSailaway is on a distinguished road
Fuel Spill
Has anyone out there had the experience of spilling fuel while heeling? This is not a problem of overfill. If my Beneteau 311 heels too far to the starboard (on which side is the fuel vent), I spill fuel, regardless of how much or little fuel is in the tank. Thanks
Old 02-07-2001
paulk paulk is offline
paulk is on a distinguished road
Fuel Spill
Sounds like your vent tube may not lead up high enough before going down & out. They''re usually led up to the top of a hanging locker, near the cabin top, before turning down to go overboard. If the vent us ending up underwater, it could also be siphoning fuel out the same way an exhaust loop that doesn''t go up high enough can siphon seawater into your engine (and sink you) when you''re in reverse or a high following sea.
Old 02-10-2001
Fuel Spill
Great News..... the dealer might have finally come through for me. It seems that there should be a loop, that''s not there,in the vent line.... let''s see if we recify the problem.. Peharps it''s clear sailing from here!
Sponsored Ad
vB code is On
Diesel fuel RSchneider Gear & Maintenance 4 4 Weeks Ago 10:39 AM
Sabre 28 Fuel Tank RickFagan Gear & Maintenance 1 10-26-2006 03:08 PM
Heaters: diesel or solid fuel? Seagypsywoman Gear & Maintenance 9 12-29-2004 03:22 PM
Fuel Return Ratio pma_foyl General Discussion (sailing related) 1 07-09-2004 11:10 AM
old diesel fuel capedoryus Gear & Maintenance 1 12-17-2002 08:14 AM
Page generated in 0.5810 seconds (65.93% PHP - 34.07% MySQL) with 15 queries
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
