Unknown electrical switch?? - Page 8 - SailNet Community
post #71 of 76 Old 04-25-2011 Thread Starter
Well I always say karma is a b*tch. But this is way over what I was expecting. I just cannot believe I found the original gauge at a boat yard sale.
Bilge pump - replaced with one that has an external float switch and wired to electrical panel with a toggle switch to run it. works great.
I also ( against my own will ) did buy the spinnaker sail from the yard sale as well.
35' long with 15 wide.... purple, blue, and white... haven't tried it, but will this weekend.
SpcAlan1 is offline
post #72 of 76 Old 04-26-2011 Thread Starter
Ok, also I got these 2 separate 'boxes' with my 10 purchase of the gauge cluster.
http://www.sailnet.com/photogallery/.../ppuser/166433
( i know I need an account with a photo sharing site - but those are blocked by work )...
The top 'box' says 'power and digital lighting' - same as my original..
The second box says 'display mode ' - wind speed and depth' and 'depth alarm'.
Since the gauges light up when I plug in the serial plug and flip the nav breaker.. i am good there.
Now how/where do these hook up to the transducers ( that are under than cabinets in cabin ) ?
From what i can see now - my original box is wired to electrical panel and then the serial cable from it to the gauges, but where do the transducer wires come into play ? am I missing a 'piece' ?
thanks.
SpcAlan1 is offline
post #73 of 76 Old 04-26-2011
I love the boat you have hanging from the davits. What is it?
teddier1 is offline
post #74 of 76 Old 04-27-2011 Thread Starter
OK, i went out to the boa last night to 'trace' the wiring.
3 wires are coming out of the 'original box '.
1 - to transducer under cabinet in cabin - maybe depth ?
2 - running under the floor on port side - maybe for speed ? ( wind or boat ) ?
3 - To distribution panel
# 1 above -
the wire leaving the 'original' box and then go to another 3x3x3 box ( very small ). no labels, no ID#, nada... then leave this box and then to the transducer.. very strange.
The gauges only light up - no numbers for depth or speed.
SpcAlan1 is offline
post #75 of 76 Old 04-27-2011
Alan, the boatspeed and depth transducers are often combined in one unit with one cable feeding them, so I would guess that IF your setup includes windspeed (always a sensor aloft by itself) and speed+depth, that one connection is for windspeed up the mast, while the other is for a thru-hull transducer for the pair.
Just an educated guess--since I don't know that rig. You'd have to check the wiring you found, see where it goes and what's left at the other end to try checking that. Although, if there's a marine electronics dealer near you that used to carry their stuff, sometimes asking for the oldest guy in the shop will bring about some hints. :-)
hellosailor is offline
post #76 of 76 Old 04-27-2011 Thread Starter
I do not know if the 'speed' gauge is for wind speed or boat speed.. doesn't specify.
But since the boatspeed and depth is usually 1 transducer (?) that would indicate i have all 3. ?
SpcAlan1 is offline
Unknown Identity 2 Umeds? General Discussion (sailing related) 17 12-05-2011 06:09 PM
Cal 20 - unknown winch herocomplex Cal 4 05-22-2010 11:08 PM
The Unknown and Unloved hriehl1 Boat Review and Purchase Forum 2 08-29-2009 10:58 PM
I want to head out into the unknown for a while jeffwagn Introduce Yourself 4 04-14-2009 11:35 PM
Unknown knotmeter odyssey23 Gear & Maintenance 0 04-12-2001 02:03 PM
