-   -   Unknown electrical switch?? (http://www.sailnet.com/forums/general-discussion-sailing-related/72862-unknown-electrical-switch.html)
SpcAlan1 03-17-2011 07:30 AM
I am redoing my DC panel to something more modern.
I have posted 2 photos, one of my original DC panel, and a photo of a switch that is not labled . When I flip the switch to 'on' the little light comes on.
Does anyone have any idea of what this is?http://www.sailnet.com/photogallery/.../ppuser/166433
Hopefully the link works.
capttb 03-17-2011 07:44 AM
Looks like it's your AC panel so the switches would be for whatever 110 volt circuits you have. Battery Charger, Water Heater or AC outlets in the cabin.
SpcAlan1 03-17-2011 07:52 AM
Ok, I will have to play around and find out what they do.
I do have a water heater and ac outlets.
my battery charger just plugs into the AC outlets when plugged into shore power.
I am plannng on moving the perko switch and replacing the 7 switch panel to something new, and adding some monitors ( 2 batteries, maybe total draw, and the override for the bilge pump.
HPLou 03-17-2011 07:54 AM
It may be a switch to turn the battery charger on with an indicator light showing the charger is on.
capttb 03-17-2011 07:59 AM
Or a switch to turn the water heater on with an indicator light showing the heater is on.
Or it may be connected to nothing with an indicator light showing the switch to nothing is on.;)
Boasun 03-17-2011 08:00 AM
Isn't that the Self-Destruct Switch??? :o
"Thank you for using the Acme Self Destruct. This boat will self destruct in fifteen seconds....Fifteen....forteen....thirteen....twelv e....Eleven....Ten.....
KA-BOOM!!
SpcAlan1 03-17-2011 08:13 AM
don't know for sure, but I do know that my battery charger plugs directly into the AC 110v and then to battery.
SpcAlan1 03-17-2011 08:14 AM
very possible... but how do I find out?
eherlihy 03-17-2011 08:17 AM
Somewhere in the Atlantic, there is a lighted bouy blinking on and off as you flip that switch. :D
Assumption is that because it is close to the AC panel, it has something to do with AC...
The two most common AC "options" are (as others have already pointed out); Battery Charger, and Water Heater. Because there is a light on it, I would guess Battery Charger.
However, because the boat looks to have some, uh... non-standard wiring, it could control virtually anything.
If it were my boat, I would be rewiring EVERYTHING connected to this panel with tinned - stranded - Marine grade AC wire.
SpcAlan1 03-17-2011 08:17 AM
Hey, also see my photo of the IMI Combi box ( under the port side cockpit seat ). It is going to the panel above the wheel, but I have no instruments in that panel... what exactly does this thing do?
