Finding data with shaft RPMs at the end of watch - Page 2 - SailNet Community
post #11 of 15 Old 03-22-2011
Yes. I'm used to recording hourly turns from the RPM counter. And at steady speeds over longer hauls it's probably pretty accurate for DRing with the Nav making the adjustments. Even though they record the turns I think everyone uses GPS now for distance traveled.
Waltthesalt is offline
post #12 of 15 Old 03-22-2011
Glad I found Sailnet
Bene505's Avatar
Originally Posted by Waltthesalt View Post
I'm used to timig a run over a measured distance (average both ways) to get make a RPM/speed table. Figure distance from the speed using the table. Calculations assuming a slip value are infreior. Slip can also change at different rpms
That's a great idea that could also be done by us amateurs, using a GPS. That way we wouldn't need to run a course, only try different rpms and let the GPS "catch up" to the rpm changes. It could really tell us if the prop had barnacles or if the bottom was getting dirty (or both).
As an aside, I'd love to make a chart showing fuel consumption versus rpm. Not exactly sure how to go about that one, short of adding a small tank to the top of my diesel inlet, then overfilling the diesel up into that tank.
Regards,
Brad
Great minds discuss ideas;
Average minds discuss events;
Small minds discuss people.
The best minds discuss sailing (and a little bit of politics). I don't know why. It's a mystery!
Bene505 is offline
post #13 of 15 Old 03-22-2011
Does anyone on this forum actually have a recorder that adds up the rpms over a period of time or are you just saying ran @1800 for 4 hours. How accurate is your tach and won,t rpm vary as conditions change(like prop comes out of water)
RXBOT is offline
post #14 of 15 Old 03-22-2011
It would be easy enough to add a rev counter to the propshaft on a boat. Epoxy on one small neodymium magnet and a dummy counterweight, put a digital counter and a reed switch up next to the shaft, $30-60 and there you go, a rev counter if you can't find one off the shelf.
Actually there are plans on the web to use a simple calculator as a counter that way too. Make it $10 that way.
And...I'm still not inclined to do it, sorry Boasun. "Too Much Stuff!"
hellosailor is offline
post #15 of 15 Old 03-23-2011
obarut's Avatar
Send a message via MSN to obarut Send a message via Skype™ to obarut
I don't think that using GPS is a good idea to determine the distance traveled. GPS calculates the distance in 3D which means upward motion of the boat due to waves is also included in the distance traveled.
obarut is offline
rpms quiz wsconner General Discussion (sailing related) 5 09-11-2010 08:35 AM
Cal 39 maximum RPMs jigs711 Cal 2 07-14-2010 03:39 PM
Why do I get low RPMs in gear only?... john232 Gear & Maintenance 14 03-30-2010 09:28 AM
Engine rpms fluctuating c40eb Gear & Maintenance 13 05-16-2009 04:28 PM
Lugging at medium RPMs StoutHeart Gear & Maintenance 10 07-11-2007 05:28 PM
