To design a ballasted daggerboard? - Page 2 - SailNet Community
post #11 of 13 Old 03-25-2011
bljones's Avatar
I am not a physicist, or a mathematician or even a rocket surgeon, but i figure to make the daggerboard compensate for the movement of crew and resistant to heeling, the daggerboard would have to weigh as much as the crew on board, which would make it impossible for aforementioned crew to raise it.
The low-buck solution is to bundle six- eight pool noodles together for each side, wrap in a sling of sunbrella with grommets sewn along the edge, then screw the floatation to the gunwales through the grommets. Much more stable, and still sailable.
Like this:
Dinghy Dogs - A Better Inflatable
It's 5 o'clock somewhere:
bljones is offline
post #12 of 13 Old 03-25-2011
PaulfromNWOnt's Avatar
What Faster said.
It would be a simple matter to make up a small set of adjustable outriggers, and turn the Opti into a sort of trimaran. The idea is to set them so they extend at an upward angle so the boat will still heel somewhat, and simply "clamp" them to the gunwhales. Yes, it will interfere with the normal handling, but as you adjust them inward this effect will be lessened along with the stability. Just like training wheels.
PaulfromNWOnt is offline
post #13 of 13 Old 03-25-2011
Glad I found Sailnet
Bene505's Avatar
If the water is deep enough, make a long daggerboard with the bottom part made out of 10 pounds of lead. With a long board, that will provide a lot of stability.
If you can't go with more weight, go with more depth with the weight you can use.
Regards,
Brad
Great minds discuss ideas;
Average minds discuss events;
Small minds discuss people.
The best minds discuss sailing (and a little bit of politics). I don't know why. It's a mystery!
Bene505 is offline
Cal 39-Internally Ballasted? devemaster Cal 4 07-15-2010 12:53 AM
Stuck daggerboard imzens MacGregor 14 04-08-2009 12:25 AM
Centerboard/Daggerboard question klwood Gear & Maintenance 3 10-10-2008 01:45 PM
Daggerboard problem santacruzin Gear & Maintenance 13 11-06-2007 05:06 PM
centreboard versus daggerboard sailingforever General Discussion (sailing related) 4 06-06-2006 01:42 PM
