Realistic Quote or Not - Page 2 - SailNet Community
post #11 of 61 Old 03-25-2011
Chastened
Ajax_MD's Avatar
You don't need to epoxy a plug in place, just pound a 1/2" wooden bung into the hole. It only needs to remain in place long enough for the "guide bit" in the hole saw to guide the saw teeth down to the hull.
Once the hole saw grinds even a slight depression into the hull, the wooden bung can be removed. A friend of mine just did this for an engine seacock.
I do hear you on the lack of time and the cold temperatures. Sucks, that.
Alacrity, 1981 Tartan 33 #168
Ajax_MD is offline
post #12 of 61 Old 03-25-2011
Seen Your Mamba
AboardIndigo's Avatar
That's excessive. I would definitely do it myself if that were the only other option. The epoxy plug is going to add what, an hour to your time lost if you do it yourself?
I can understand the time=money and hostage to weather conditions factors, but $1380 is a lot of 'time well-spent' money.
AI
AboardIndigo is offline
post #13 of 61 Old 03-25-2011
another way to redrill the hole is to, glue a thin piece of ply over the hole. then drill thru the plywood, which will guide the new larger holesaw. the hole saw guide bit will hold it until the bigger hole is into the ply. a good glue for this is a good old fashioned hot glue gun.
in my opinion trying to put a plug into a hole saw is risky, if it comes out the hole saw can go running across the surface. driving in a tapered plug and drilling using the plug to guide the bit is better, but the ply method is easy and safe.
scottyt is offline
post #14 of 61 Old 03-25-2011
bljones's Avatar
forget plugs- use a 1/4" to 3/4" step- drill bit.
Amazon.com: Neiko 3-Piece Titanium Step Drill Bits Set M2 Steel - 28 Sizes, SAE: Home Improvement
16 hours- Neptune's nads, were they watching the epoxy dry and counting it as labour time?
It's 5 o'clock somewhere:
bljones is offline
post #15 of 61 Old 03-25-2011
Chastened
Ajax_MD's Avatar
Ah, I did not say to put the plug in the hole saw, I meant for him to drive it into the hull as you said. Something got lost in translation.
bljones has the best solution- the stepped drill bit. I didn't know they made them that big!
Ajax_MD is offline
post #16 of 61 Old 03-25-2011
Tim R.'s Avatar
DrB, which yard quoted you this price?
Tim R.
Our Carina is for sale
1997 Caliber 40LRC
Tim R. is offline
post #17 of 61 Old 03-25-2011
will the Stepped Drill chip the coat on the out side?
get a 1/2 in hole saw and make a 1/2 guide to then place on the 3/4 hole saw to make sure your on center, then follow the steps needed to install the new thru hull, Compass Marine "How To" Articles Photo Gallery by Compass Marine at pbase.com in the link all the info and photos Belong to MaineSail and i have not rights to them i am just linking his how to reports.
lickingcardboard is offline
post #18 of 61 Old 03-25-2011 Thread Starter
DrB
Not going to say
I like the guys in the yard and they also have my boat. They have FG guy that does great work.
Like I said if they would have come in about 1/2 of what they quoted, I would have bit. They may be flat out for work and just put this out there to see if I would bite. Some folks would. If I was flat out, I certainly wouldn't aggressively bid something.
I will go back to them and ask them to sharpen they're pencils, but in the end I will probably end up doing it myself.
Thanks all for the great advice and sanity check.
DrB
If you liked my advice/response, give me some rep points. If you didn't......well what do you expect, it was free.
DrB is offline
post #19 of 61 Old 03-25-2011
Good GAWD. Buy a Dremel tool with the various rotary attachments and enlarge it yourself. It might take an hour. Buy a small tube of 3m5200 from Ace Hardware and seat the thru hull. Job done in a couple hours.
What does weather have to do with this? You can work in the rain with a battery operated dremel or battery operated drill. Buy a few feet of #10 tinned wire for bonding the thru hull to your engine too. You will need a pack of Ancor tinned crimp eyelets and a crimper. You need the crimper in your tool box anyway.
Frogwatch is offline
post #20 of 61 Old 03-25-2011
One other thing, the old thru hull prob has a wooden backing plate thru which you will need to enlarge the hole with a rotary rasp. When you do, get some 5 minute epoxy to spread on the now exposed wood in the hole to seal it.
Quote about sailing shelly67tn General Discussion (sailing related) 12 10-15-2008 07:09 PM
Interesting Quote.... Jeff_H General Discussion (sailing related) 52 01-21-2007 10:36 PM
Cruising Quote duffer1960 Cruising & Liveaboard Forum 14 04-09-2006 03:24 AM
Cruising Quote duffer1960 General Discussion (sailing related) 3 01-18-2005 07:24 AM
