Realistic Quote or Not - Page 3 - SailNet Community
post #21 of 61 Old 03-25-2011
read this Compass Marine "How To" Articles Photo Gallery by Compass Marine at pbase.com if your looking to do the work your self this might be something you want to look into
The Link Above contains Photos and information that belongs to MaineSail, i am just linking his work.
p.s. thanks MS for the work and the info.
lickingcardboard is offline
post #22 of 61 Old 03-25-2011
Tim R.'s Avatar
For that matter, just hire MaineSail to do it for you. I am sure he is more reasonable than your yard.
Tim R.
Our Carina is for sale
1997 Caliber 40LRC
Tim R. is offline
post #23 of 61 Old 03-25-2011
Another option with the hole saw is to drill a hole the right size in a piece of 1 foot square plywood, and have a helper hold that 'guide' centered over the original hole.. then simply insert the hole saw and start the cut. Once the hole saw has seriously started you don't need the center guide anyway. This avoids having to "plug" the original hole at all.
Faster is offline
post #24 of 61 Old 03-25-2011
SailingWebGuy's Avatar
My vote is for Boasun's suggestion. It's really simple and I've used the same method dozens of times (not all on thru hulls of course). Just thread the 1/2" hole saw inside the 3/4" hole saw. Drill away. There's no need for plywood or plugs. The 1/2" hole saw will be a perfect guide.
My complete refit is taking completely too long!
SailingWebGuy is offline
post #25 of 61 Old 03-25-2011
Sundance 23
carl762's Avatar
Awesome suggestion SailingWebGuy.
Water is Life
carl762 is offline
post #26 of 61 Old 03-25-2011
Well, you could go back to the yard and pitch them the job for $700. If they don't have any work on the table, they'd probably take it. But I'd still vote for doing the job yourself. Then you'll have the tools and knowhow to do it again in the future.
LauderBoy is offline
post #27 of 61 Old 03-25-2011
Actually, it may or may not work because they're pretty close in size. The 1/2" might not fit inside the 3/4". And the center piece (not sure of the correct terminology for it) might not have enough thread to fit both. I have a Milwaukee hole saw kit and just checked. 1/2" and 3/4" won't work. Maybe other brands are different.
post #28 of 61 Old 03-25-2011
Omatako's Avatar
What sort of a labour rate would that be then because I did a hole enlargement in my own boat from start to finish (not counting removal of the old fitting which the OP has already done) in less than an hour.
On this application the wooden bung is the best fix because it doesn't even matter if the new hole is centred on the old one, just so long as the hole saw cuts through virgin hull surface.
This is a simple, basic DIY job. The price the OP was quoted is outrageous and any acceptance of such a price is the reason why all boaters get continually raped by these people. We all (me included) have an age-old perception that marine work is always going to be more expensive. This iniquitous quote is where it all starts.
Arthur C. Clarke
Omatako is offline
post #29 of 61 Old 03-25-2011
Thats why you cut a plug in the 1/2 size and then put that on the guide bit for the 3/4 size as a guide to keep it on center, then follow the install directions posted before.
post #30 of 61 Old 03-25-2011
Argyle38's Avatar
The best part of all this is, when you are done with this, you will have spent maybe 5 hours, tops, on the job. You can then say to yourself, that you have effectively made $270/hour. Not too shabby Mr. Moneybags!
I would go with the tapered plug method. Stick it in the hole until it seats. Mark the spot where it goes into the whole. Cut it off at or near that mark and then tap it in with a rubber mallet. Cut, seal up the facing edges of the hole with some epoxy, bed the whole thing well, replace the backing/front plate if needed. Oh, if you use 5200, a future owner will curse your name to Hades if this job ever needs to be re-done.
S/V Argyle
Downeaster 38 #40
Argyle38 is offline
Quote about sailing shelly67tn General Discussion (sailing related) 12 10-15-2008 08:09 PM
Interesting Quote.... Jeff_H General Discussion (sailing related) 52 01-21-2007 11:36 PM
Cruising Quote duffer1960 Cruising & Liveaboard Forum 14 04-09-2006 04:24 AM
Cruising Quote duffer1960 General Discussion (sailing related) 3 01-18-2005 08:24 AM
