04-01-2011
Unfortunately, the boats that you are looking at will not work from a towing perspective. Here are a few things that you need to consider when towing:
Weight- The maximum towing capacity for a Durango is 7,400lbs for a 2wd one with only a driver. Realistically, it will probably be 6000lbs of which 2000 lbs goes to the trailer. A 4,000 lb boat is pretty small, I don't even know of any 30'ers that would meet this requirement. Even if you upgrade to a one ton dually you are unlikely to find something in the 40' range. You would probably need a medium duty truck and a CDL.
Height: The total height will be from the bottom of the keel to the highest point on the cabin/stanchions plus at least a foot for the trailer. Being much over 12' is pretty limiting.
Width: It depends on the road but much over 9' gets problematic. You can get wide load permits but they are expensive and inconvenient.
There are 2 ways to deal with this. First, you can look at a boat that is trailerable by a Durango/whatever vehicle you are willing to buy. The other option is to buy a boat that you can't tow and pay a professional hauler to move for you. You still need to make sure that it isn't too big for them.
