04-07-2011
Originally Posted by ImASonOfaSailor
You would need a deviation Table Degree form your area that ur at! You should get those where you would get your updated chart from and you should get a Tide table also while you are there...
Ok I am have a hard time in subtracting 2400 time and adding is there a way you guys understand this better? Thanks
The 'Variance' (magnetic declination) is geographically specific. The variation, including annual adjustment can be found on the compass rose on a chart.
The deviation is specific to each vessel and has to do with the effects of the boat's structure, or systems (electrical etc.), on the compass. The deviation will be different for each heading. To find the deviation involves sailing along known headings and establishing the difference between true and compass bearings. Once variation is accounted for the difference is deviation. This will change for every heading, so the process has to be repeated until you have established a deviation for each heading. This information should be charted and is used to do your TVMDC calculations.
There is an article on this HERE.
1989 Hunter 30'
Southern Georgian Bay
'Nautai te salutamus!'
