So, I Installed a New Toilet - Page 3 - SailNet Community
post #21 of 25 Old 04-11-2011
Toilet Size?
Tom,
Looks like a nice job. Did you install a standard tiny marine toilet? I can't tell for sure from the photos. When I upgraded my toilet last year I went for the larger bowl. It's a bit more comfortable to sit on and a better target while under way. A worthwhile upgrade.
Speaking of venting, I'd like to find a 1 or 1.25 inch vent to ad to my tank. I've shopped around and they do not seem to exist. 5/8 inch seems to be standard and it really does not offer any air exchange at all.
PAUL
newpbs is offline
post #22 of 25 Old 04-11-2011
mitiempo's Avatar
Stainless, bronze, or Marelon, they come in all sizes.
Brian
mitiempo is offline
post #23 of 25 Old 04-11-2011
Vents
HTML Code:
I'm not having any trouble locating a large variety of through hull fittings. I'm asking about vents. The appropriate fitting would be chrome finished and have a fine mesh screen to keep critters out. The largest that I have come across was 3/4 and rather ugly.
newpbs is offline
post #24 of 25 Old 04-11-2011
mitiempo's Avatar
The problem with vents is they are too small. That is why the through hulls are a better idea. They make good vents and allow for good airflow.
Brian
mitiempo is offline
post #25 of 25 Old 04-11-2011
TakeFive's Avatar
Originally Posted by Minnewaska View Post
If at all possible, I would highly recommend a larger holding tank. One of the biggest reasons that waste lines stink is that way too little fresh water is flushed behind the waste to clear them out and push the nastiness all the way to the tank. That can require a full gallon of water for each flush, although, that highly depends on how far away the tank is.
For this reason I am about to take out my marine head and replace it with the Porta-Potti that I've had unused in the basement for 20 years.
I also only have a 6 gallon holding tank. I spoke to a previous owner who told me he replaced the 12 gallon tank because it was rubbing against the steering cables. When I looked over the installation I did not like what I saw. The holding tank is significantly higher than the toilet, so you've got to pump uphill. If your seals aren't perfect, everything in the hose will gradually come back into the toilet bowl. There's about 6' of 1.5" ID hose, connected to about 2' of what looks to be about 2.5" ID hose. That's a dead volume of over 1 gallon, so you need to flush with at least that much water, and actually more if you realize that the flow is not perfect plug flow. (Sorry for the engineer-speak.) So you get less than 6 flushes from the darned thing, or have to accept pee and whatever else backing up in the toilet bowl.
To make matters worse, my marina's pump-out station malfunctions over 80% of the time. The suction pump is located on short 150' from the suction hose (which is at the gas dock), and 4-10' higher (depending on tide), so it won't prime itself. I told them they need a priming pump at the gas dock to push river water through the empty hose back to the suction pump, but they won't listen.
My Thetford 155s has a 4.3 gal waste tank, but will accommodate about 45 flushes because there's no dead volume to fill. I'll keep the holding tank and hoses in place (plugged, of course) so I can reinstall it if I ever sell the boat.
2001 Catalina 34MkII Breakin' Away (at Rock Hall Landing Marina)
PO of 1998 Catalina 250WK Take Five (new owners relocated to Baltimore's Inner Harbor)
1991 17' Trophy (Lake Wallenpaupack)
TakeFive is offline
Installed a helix mooring anchor last weekend... Joel73 General Discussion (sailing related) 73 08-05-2016 03:00 PM
Who has PSS shaft seal installed? orientalnc2010 Pacific Seacraft 6 04-25-2010 07:03 PM
Removing Wheel with Autopilot Installed? Tanley Gear & Maintenance 1 02-25-2010 11:32 PM
Just Installed a High Output Alternator dmoreau Electrical Systems 5 11-22-2009 09:09 AM
Installed Teak Toerail & Cockpit Seats 1970Columbia34 Gear & Maintenance 10 05-28-2009 05:18 PM
