  #11
Old 04-12-2011
Mark1948 is on a distinguished road
Yes, VC 17 does dry very quickly. If you have a good job of painting you may not need to apply every year. Also note that vc 17 changes color very quickly when exposed to the elements.
  #12
Old 04-13-2011
DonScribner is on a distinguished road
Go to WHOLESALEMARINE.com. I bought my bottom paint for $30 less per gallon, with free shipping. Or, when you go to Worst Marine, bring the competitors webpage and they are supposed to match the price.
  #13
Old 04-13-2011
estopa's Avatar
estopa is on a distinguished road
I would think she would need a full gallon. When i use SSB on my 22 foot I have a little left over for the drop-down centerboard and the rudder.
George Paiva
"estopa" - [est'opa] is portuguese for Oakum.
1986 Oday 222 #686
  #14
Old 04-13-2011
MaryRoseErie's Avatar
MaryRoseErie is on a distinguished road
I got in contact with the previous owner, she says that the paint is VC17.
She told me she only uses one small can.
Should I sand or scrub before painting?
  #15
Old 04-13-2011
MarkCK's Avatar
MarkCK is on a distinguished road
Definetely scrub it down so that bottom is clean before you apply the paint.
  #16
Old 04-22-2011
The paint VC17 says that I need to sand it down before painting. Is this necessary? I'm only doing a touch up coat.
  #17
Old 04-22-2011
Silverstreak01's Avatar
Silverstreak01 is on a distinguished road
I will be keeping the boat in fresh water lake 4 to 5 months, would painting the bottom really be needed??
  #18
Old 04-22-2011
Siamese is on a distinguished road
maryrose-
No need to sand. Just use a scotch brite pad and water. If you have any particulary rough areas, wrap some 320 grit wetsand paper around the scotch pad and sand wet. Probably not necessary, though.
Use the search function on this site, as there was recently, within the last 6 weeks, a discussion on applying vc17.
This is one of the easier jobs you'll perform on your boat. I don't know if that's good news or bad news
  #19
Old 04-23-2011
labatt's Avatar
I'd rather be sailing
labatt will become famous soon enough
Yes - you'll get slime and other growth along the waterline and bottom if you don't. Plus - depending on where you are - some crustaceans might adhere to the hull. We used to be in Champlain (fresh water) and even with bottom paint we still got some slime and zebra mussels. I can't imagine what it would have been like without paint.
s/v "Pelican" Passport 40 #076- Finished Cruising - for the moment -
"Don't dream your life, live your dream" - Bob Bitchin'
"I'll see it when I believe it" - Me
You may post attachments
You may edit your posts
?'s before painting my bottom. Perithead Gear & Maintenance 1 03-28-2011 09:42 AM
bottom painting under bunks with boat on trailer chrispeck SailNet FAQ's 9 06-03-2010 04:39 PM
bottom painting in bahamas chuck5499 Gear & Maintenance 8 12-03-2008 10:12 PM
Re: Moving JackStands when Bottom Painting / Wet In-Water Winter NewsReader Mass Bay Sailors 0 02-15-2007 08:15 AM
bottom painting lat38col36 Racing 2 01-21-2003 05:53 PM
SEO by vBSEO 3.6.1
