Beneteau 343 prop walk direction - SailNet Community
post #1 of 6 Old 04-24-2011 Thread Starter
This is probably a simple answer, but I seem to be finding conflicting info online.
I am chartering a Beneteau 343 and, in the process of being nervous about maneuvering in tight quarters, and trying to verify which way the prop walk is going to affect me going astern.
My impression was that it was a left-hand prop, but most everything else I read indicates that the boat walks to port when in reverse, which would indicate it is a right hand prop.
Can anyone clarify, or simply tell me which way I should expect this boat to walk when in reverse?
Thanks in advance,
-- Bass
basssears is offline
post #2 of 6 Old 04-24-2011
My US made 343 had a right hand prop. The boat walked to port in reverse. But the walk was predictable & could be used to my favor in those tight quarters.
Deadhead is offline
post #3 of 6 Old 04-24-2011 Thread Starter
Thanks, I was planning on using it to my advantage, I just wanted to be able to visualize it in my head which way it would take me before I pulled out in front of the whole world ;-)
-- Bass
post #4 of 6 Old 04-24-2011
Are all 343s powered with the same engine and gear? If you can find out the engine/gear combination then you should be able to confirm LH vs RH prop... as you say, RH will walk to port in reverse...
Faster is online now
post #5 of 6 Old 04-24-2011
While tied to the dock put it in reverse and look over the side, if most of the wash is on starboard side it will propwalk to port and vice-versa. There is enough difference that you won't have trouble distinguishing. I'd bet it's righthanded, I haven't seen a left handed prop on a boat from the Big 3 in a long time.
"Just call me TB"
capttb is online now
post #6 of 6 Old 04-25-2011
At the dock, tied up, bump in reverse and you'll feel the prop walk direction immediately. Forward is the opposite. When you take it out motoring, just fiddle around... make some tight circles, straightline, coast, then reverse to see how long it takes the prop to bite. The biggest thing is to just relax. You'll figure it out in short order.
puddinlegs is offline
Prop walk with a Max Prop ikent Gear & Maintenance 19 06-05-2011 08:32 PM
Beneteau 473 prop zize tomaz_423 Gear & Maintenance 25 12-05-2010 10:53 AM
Prop Walk davidpm General Discussion (sailing related) 13 08-31-2010 12:49 PM
prop walk bkw Learning to Sail 19 09-01-2006 01:40 PM
Prop walk - Catalina 30 rmf1643 Learning to Sail 4 08-03-2001 12:01 AM
