Old 04-29-2011
souljour2000's Avatar
souljour2000 is on a distinguished road
Sailing with furling jib only...instead of main only
I have an older Seafarer 24 with a masthead rig on which I usually have a %100 furling jib and a fairly old and stretched mainsail. I often use just the jib to get out of a mooring field or to run with the wind when it's going my way and I have noticed that I don't see many others doing the same..mostly just folks using their mainsail by itself....when going with only one sail.
I have heard somewhere that using just the jib can stress the rig but I usually furl the jib in some to about 80 percent and I have a strong split backstay and generally a strong rig with two lowers and an upper that are probably oversized by today's standards on a boat of this size...1/4 inch. Is this a good idea..seems okay to me but I still have doubts and don't want to damage my rig or stress it unnecessarily. Thanks in advance for any comments
Old 04-29-2011
Sublime's Avatar
Quirky
Sublime is on a distinguished road
How does that stress the rig any more than going under main and jib?
My drascomb has two side stays and no back stay. When reefing the main and jib isn't enough, it's recommended to drop the main and go under jib and mizzen alone. The difference I suspect is that I can use the mizzen to balance. So maybe it's stress on the rudder is what people question. But if you're not hard over to keep her going straight, I don't see any difference from being under main alone.
A ship in harbor is safe, but that's not why ships are built.
My girls:
1974 Alcort Minifish-Minifish
2001 Drascombe Lugger-Penelope
2004 Hunter 260-Miss Muffet
Old 04-29-2011
ccriders is on a distinguished road
There is an article somewhere on the internet about this exact issue. There have been reports of rig failure while sailing with jib alone. As I remember the story, it involved rigs with only one lower shroud and significant mast "pumping". The conclusion of the article is that for rigs with two lower shrouds you can run with either main alone or jib alone, but that if you have a single lower shroud you should run with main alone as the boom and sail reinforce the mast and eliminate "pumping".
In your case, it sounds like you have a very stout rig and if you do not see any "mast pumping" then you are probably safe with either jib only or main only.
John
Old 04-29-2011
priscilla's Avatar
priscilla is on a distinguished road
Not so much in very lite air but the jib alone will stress the rig. The mainsail supports the rig...main and jib together is the way to go.
Priscilla
Old 04-29-2011
WouldaShoulda's Avatar
AEOLUS II
WouldaShoulda is on a distinguished road
I'm calling Mythbusters!!
Old 04-29-2011
scottyt is on a distinguished road
heck i sailed under jib alone alot, even a 155 genny. on my boat my main is small compared to a 100 % jib, even smaller with the 155. i think it depends a lot on the rig design, there is no way my main gives any support to the mast.
also, look at running under a spin, it is just like a big jib and they get run with out the main all the time.
Old 04-29-2011
delite is on a distinguished road
Once in a while when I go for a quick sail to get away for a couple of hours by myself I will be lazy and only pull the 150 Genoa and not raise the main. It doesnt sail the same but I dont think it does any damage. Interested to hear others thoughts.
Old 04-29-2011
Da Most Educated Red Neck
rockDAWG is on a distinguished road
Yeap, I see a lot of sailboats sail with jib only around Bay Bridge in Chesapeake. bring out the jib is much easier than to raise the main.
Starting 2012 sailing season: Done with the timeshare boat.
Old 04-29-2011
Thanks for the comments folks..like I said..I got two sets of lowers and an upper...the mast seems supported well and the split backstay adjustment should probably be tightened...the spinnaker example seems to be a good one Scotty.....overall it seems okay to me as long as you have good support on the mast but I am not knowledgeable about rig stress much yet.
Old 04-29-2011
tommays's Avatar
I really dont see how it would stress the rig
i would look at the wire under the furler once in a while a my unit had worn a got bit of wire away under the upper bushing suggesting there is a good bit of load there
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
roller furling main MikeGuyver Gear & Maintenance 13 12-13-2008 08:16 PM
Adding A Furling Main To A 310? BVIMoonchaser Catalina 6 04-12-2008 05:18 PM
Roller furling main zakynthos Gear & Maintenance 9 10-18-2007 11:24 PM
furling main bkw Learning to Sail 14 02-11-2007 05:26 PM
Furling Main Sails Dking59 Boat Review and Purchase Forum 18 03-17-2004 04:23 PM
