04-29-2011
Morgan 33 O.I. Perryville
There is a very simple rule when it comes to outboard motors. The outboard motor's cavitation plate must be slightly below the bottom of the hull. This permits water to flow freely beneath the cavitation plate, which provides the most efficiency. If the cavitation plate is higher than the bottom of the hull, the engine will not function effectively. If the engine is too high above the bottom of the hull, the boat will not ever move. This, however, applies to a transom mount ONLY. Outboard engines mounted on stern brackets and positioned some distance from the boat's transom will still function fairly well just as long as the cavitation plate is still beneath the water's surface. If the plate comes out of the water, which is a distinct possibility with offset mounted stern brackets, the engine cannot draw in cooling water--even if the prop is in the water. The cooling water inlet on most outboards is just beneath the cavitation plate, and while it is self priming, the inlet must be submerged by at least an inch or two in order to function.
Good Luck,
Gary
