Old 07-07-2003
ricekrgr is on a distinguished road
RV oven?
Any thoughts on using an oven intended for RV use on a boat? Thanks
Old 07-07-2003
jbanta is on a distinguished road
RV oven?
Ricekrgr
I see no problem withnthat just expect to replace it every year...
Old 07-07-2003
paulk's Avatar
paulk is on a distinguished road
RV oven?
How are you going to set up the gimbals?
Old 07-08-2003
Jeff_H's Avatar
Super Moderator
RV oven?
Marine stoves have a number of safety features that are intended to allow them to operate safely at angles of heel and in the confined space of a cabin. These features would not be present on a RV stove. I imagine that putting an RV stove aboard might void your insurance in a fire as you have installed a device that would not meet the required marine safety standards.
Old 07-08-2003
sadie14 is on a distinguished road
RV oven?
This is one area where I feel VERY strongly that you need a marine-designed item. You need the stainless material that will be in a marine stove and not in an RV unit. You need the safety items in a marine stove made for the marine environment.
In many ways items from land can be used successfully on a boat, this is not one of them.
Old 07-08-2003
RV oven?
Thanks,
I thought it was a bad idea, just had to ask anyway.
Bob
underperforming oven meaboater Gear & Maintenance 4 11-25-2003 02:14 AM
update alcohol stoves realitycaptain Gear & Maintenance 9 10-13-2003 05:40 PM
shipmate oven crazy sailor Gear & Maintenance 2 11-04-2001 04:55 AM
Where to find propane oven sunspotbaby Gear & Maintenance 0 10-19-2001 12:23 AM
