Generator On A 25 Feet Boat ? - Page 2 - SailNet Community
post #11 of 26 Old 05-08-2011
I would use the honda, keep it well coverd when not in use and but a cheap co alarm btw what honda do you have that weights 70 lbs?
motion300 is offline
post #12 of 26 Old 05-08-2011
Crotchety Old Member
tomperanteau's Avatar
Keep this in mind when you run it.
The family and I anchored out inside the breakwater so that we could leave for the island early. I put the generator up in the cockpit and started it thinking that it would be okay there. There was little to no breeze. The heavier exhaust came down and settled into the cabin. We were able to run the bilge blower and open the boat up to clear the gases, but it was unpleasant for a while.
Even on the roof I would not run it unless there was a bit of a breeze.
Capt'n Tom Living Aboard 50/50
S/V Footprints
Youtube
1976 41' Morgan Out Island Sloop. Refitting and redoing her interior for an extended voyage.
tomperanteau is offline
post #13 of 26 Old 05-08-2011 Thread Starter
soyuz's Avatar
i have 2 demone marines RV27 as batteries,i think i will need to recharge every 3 days or so.i dident weight the the generator but it must be in between 70-100
lbs. i am planning recharging them for about 5-6h and in the mean time will be on the beach ect no way we gonna stay on the boat when its running.
S/V Grey Goose
Cs 36
home port: Gaspésie.
soyuz is offline
post #14 of 26 Old 05-09-2011
Ilenart's Avatar
Soyuz,
you may want to check what the DC output of your generator is. I used to have a Honda 2000 unit and the DC output was buggerall, 5-10 amp, really only designed for trickle charging. Most of the output was AC, which meant you needed a Battery charger than runs off AC. I had mine connected to a 40amp battery charger, which meant I only needed to run the gen set for 1-2 hours.
Ilenart
Ilenart is offline
post #15 of 26 Old 05-09-2011
Ahh, yes, one of my favorites – kroozers who vacate their boats in an anchorage when running an engine or generator for charging purposes… Extra points, if you chose to do so an hour or two before sunset…
Trust me, you won't make many new friends among other cruisers in harbors or anchorages if you make such a drill part of your regular routine...
Lashing it to the mast sounds excellent, perhaps with some luck the world will have one less functional portable generator aboard a cruising sailboat by the end of your voyage… (grin)
I’m, a bit perplexed, how significant can your electrical demands be on such a boat? Seems even a modest solar panel could go a long way towards keeping your bank topped up… And, even with only a small alternator coupled to your engine, you are likely to be doing a LOT of motoring on that trip, especially as you get further and further upriver…
Nothing really wrong with a portable generator for emergency back up on a cruising boat (I sometimes carry a Honda 1000, myself), but injudicious or inconsiderate use of them is rapidly becoming the bane of otherwise peaceful anchorages from Maine to the Bahamas, and beyond…
JonEisberg is offline
post #16 of 26 Old 05-09-2011
I'd be leary of leaving something like that running unattended for 5-6 hours on my boat, I know you won't be far most of the time but I've had fuel lines split on a genny before, and other bad things.
What Honda genny do you have, with a charger 5-6 hours should get the batteries up thought bulk charge and will be charging at just a few amps of finishing charge, which you don't need to do every time.
You have about 200AH of batteries so you shouldn't use the lower 100AH, the upper 100AH most batteries are fine with being at 90% if they are being worked, charge to 90% discharge to 50% then recharge to 90% then every week or three fully charge to 100%+,
From 50% TO 90% you can charge at a high rate, so 40 amps so to recharge from 50% to 90% should only take 2 hours, if you can get a charger that will push that hard, at 70+ lbs it sounds like you have a 2500-3000 watt genny that can run a good charger,
Then a small, $100 solar panel will make a big difference in charging the last 10% every day, perticualy if you run the genny in the morning.
Oh yes and also have a good cruise, sounds like a fun trip,
P35juniper is offline
post #17 of 26 Old 05-09-2011
Cruising on a boat of that size is like camping. I almost never take a dock when cruising and wouldn't think of having a generator aboard. When it gets dark look at the stars or go to bed. Trim your power consumption.
Hudsonian is offline
post #18 of 26 Old 05-09-2011 Thread Starter
soyuz's Avatar
My generator is a honda eg 1500c,i am not sure at all how long it would take to recharge both batts cause i never done it before so all is guessing so far.I was worried about the weight on the roof and all that but i found a safe spot where i can put it inside the boat where its safe.I understand advise to go with solar panels may put 1 but i still need the big recharge power.JON i am not taking the st-laurent i am in baie-des-chaleurs so we avoid engine most we can also i would never run the Gen when peps are around, we will cruise in realy quiet zones where you barely see any boat all day never mind sailling one.
thanks for the advice guys.
S/V Grey Goose
Cs 36
soyuz is offline
post #19 of 26 Old 05-09-2011
EJO
Dutchman
EJO's Avatar
Solar panels work when there is sun, which is great for you people on the West Coast and South/SE Coasts, but here in the "Northern" part of the country we don't see much strong sun that often, so use your gennie, strapped to the mast and keep your consumption to a minimum.
Skipper E-J
S/V "Sailmates" 1973 IRWIN 32 Classic
I want to live and sail forever, so far so good[/SIGPIC]
EJO is offline
post #20 of 26 Old 05-10-2011
If you strap it on the foredeck, it will be wetted with salt water, which will require that you put it in something waterproof. I would think that salt moisture would find its way past a simply cover and oxidation would be rapid. It might last the two months, but that is pretty expensive to ruin a generator for the trip.
Have you considered selling the genset to fund a small solar array? I would think you would have very limited needs and it wouldn't need to be all that large or sophisticated. You might even get away with a portable setup.
Jeanneau 54DS
Minnewaska is offline
Air X Wind Generator on a 30 foot boat ? Freesail99 Gear & Maintenance 5 03-18-2009 01:10 PM
Help costing a generator and lots of generator questions... labatt Gear & Maintenance 10 10-16-2008 02:01 AM
With Both Feet TheWastedYears Introduce Yourself 2 09-22-2008 04:53 PM
Best cruising boat (24 feet or less) cnjrojas Boat Review and Purchase Forum 9 02-02-2008 05:24 PM
New Boat 32-34 Feet max-on Boat Review and Purchase Forum 27 08-18-2004 08:13 AM
