05-08-2011
formerly posting as eryka
Originally Posted by Faster
... that are fairly complicated to install depending on just how the boat was built, access under liners etc, as you need to find a good accessible place for the unit itself plus you need to run ducting or hoses throughout the boat. But it is great heat.
If the boat is smaller with a relatively open interior a much more economical method is to use a bulkhead mounted heater - they are available in Diesel and propane versions.
In contrast to this, we first started out looking for a "stove-type" heater such as the one shown. For the ambiance as much as the simplicity. Ended up with the Webasto because we had no bulkhead on which to locate this heater and the configuration of our topsides make installing the chimney problematic. We mounted the Webasto directly under the companionway stairs and vented it into the main cabin, using no ducting at all. It makes the main cabin toasty and leaves the V-berth somewhat chilly, which is what we prefer for sleeping in any case.
But if we'd had an aft cabin or a door closing off the V-berth or a somewhat less open layout ducting would have been necessary. I guess my point is not to rule out this type of heater because of the ducting issue; depending on your boat it may or may not be necessary to add ducting.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Cinderella, CSY 33, Photo by Joe McCary
Regret for the things we did can be tempered by time; it is regret for the things we did not do that is inconsolable. - Sidney J. Harris
Shameless self-promotion - my blog for the Annapolis Capital newspaper is moving to a new location: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. but there are still some glitches to be worked out. Until then, I'm posting at: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
and like To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. !
