Lee cloth installation - Page 2 - SailNet Community
post #11 of 14 Old 05-10-2011
Glad it all worked out. How long were the screws (ie how much meat did they catch)?
Just for future reference, you can counter sink a flat head bolt and require zero clearance.
Jeanneau 54DS
Minnewaska is offline
post #12 of 14 Old 05-10-2011 Thread Starter
The screws were 1/2", and caught most of the 1/2" plywood. I did not use the grommets in the fabric at all. I made new holes (with a heated ice pick).
mainemandean is offline
post #13 of 14 Old 05-11-2011
Not really helpful for you, because you already have your cloths, but my plan is to be able to tuck them completely under the cushion and let my weight and friction hold it in place. I think I remember reading that somewhere. The top will of course be secured above the bunk.
WanderingStar is offline
post #14 of 14 Old 05-11-2011
Boasun's Avatar
And if you have no way to secure a lee cloth for the moment then a rolled up blanket and your boots placed under the edge of the mattress will keep you in place unless it is really bouncy out there.
A lee rail with the risers (two of them) going into slots at the edge of your mattress has been used o various vessels. Some fancy and some plain they work very well and gives good support when you lay against them. The ones properly made are strong enough to support you weight.
1600 Ton Master, 2nd Mate Unlimited Tonnage
Maritime Instructor
S/V Rapture
Boasun is offline
Recommended fiberglass cloth cghubbell Gear & Maintenance 10 04-16-2010 11:55 PM
roving, cloth or mat? scosch Gear & Maintenance 4 12-12-2008 11:21 PM
What do you think of this lee cloth install? labatt Gear & Maintenance 22 04-18-2007 01:07 PM
Old Sail - What Cloth To Use ? ? ? mrblimp General Discussion (sailing related) 3 07-25-2006 10:16 PM
Sail Cloth AF NS UK sailnaway Gear & Maintenance 3 02-19-2005 08:39 PM
