Old 05-09-2011
Bene505's Avatar
Glad I found Sailnet
Bene505 will become famous soon enough Bene505 will become famous soon enough
Organizing deep chest fridge & freezer
Has anyone figured out a way to make good use of the space in the big chest-type fridges and freezers?
We are just starting to really use ours, and could use some suggestions. We have a little shelf, but things would roll off it when heeling. And the bottomof the fridge llooks like it will have a small puddle most of the time. (The drain pump doesn't get all the water.) Maybe that's the place to keep cans of beer.
I'm thinking about getting some baskets with cords attached, so we could pull up the baskets from below.
So how do you pack your fridge?
Regards,
Brad
Old 05-09-2011
rotrax is on a distinguished road
Hi-that is exactly what we have on the baskets on our IP350, long ice hockey laces.Work a treat too.
Old 05-09-2011
wingNwing's Avatar
formerly posting as eryka
wingNwing is on a distinguished road
Yes, we have a set of plastic baskets from a dollar store and they're color coded - the orange one is dairy, the green one is vegetables, etc. They are an open mesh design so the cold air can circulate. They even stack so we gain storage space.
Cinderella, CSY 33, Photo by Joe McCary
Regret for the things we did can be tempered by time; it is regret for the things we did not do that is inconsolable. - Sidney J. Harris
Shameless self-promotion - my blog for the Annapolis Capital newspaper is moving to a new location:
but there are still some glitches to be worked out. Until then, I'm posting at:
and like
Old 05-09-2011
GulfTriton is on a distinguished road
Just fill the whole thing with beer and don't worry about it.
Old 05-09-2011
jimrafford's Avatar
jimrafford is on a distinguished road
We have separate freezer and fridge compressors. One of the first things we do after getting the freezer to temp. is dump a couple of bags of ice in the bottom. Having a frozen mass of ice helps in the bottom reduce the cycles of the freezer compressor.
We use plastic baskets to keep things organized.
Jim
S/V Deja Vu
CS 40
Old 05-09-2011
SPC SPC is offline
SPC is on a distinguished road
It is also important to keep it full. If necessary, use milk cartons, large zip bags, etc full of water. When you open a spill cold air, spill as little as possible and maintain the cold mass.
Old 05-09-2011
Minnewaska will become famous soon enough
Ditto. Exact program here.
Jeanneau 54DS
Old 05-09-2011
erps's Avatar
the pointy end is the bow
That's one of two strategies that we use. The other is to put everything we need at the very bottom.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
Old 05-09-2011
Siamese is on a distinguished road
Keeping a freezer full is a bit of a myth. If your ambient cabin temperature is 80 degrees, and your freezer is 28 degrees, it takes energy to maintain an item in your freezer at 28 degrees. There's no free ride. Without energy, each item will return to the ambient cabin temp of 80 degrees. As you increase the number of items (mass) to be kept at 28 degrees, you'll use more energy.
If you add ice initially to cool the other items and reduce energy costs, you will soon be paying to keep that ice from turning to water.
Old 05-10-2011
Originally Posted by Siamese View Post
Keeping a freezer full is a bit of a myth.......
From personal experience, ice will melt more slowly in a cooler that is full to the top than one that is mostly air. If the heat transfer must pass through the insulated walls, rather than into warmer air introduced into the vessel when you open it, that would makes sense.
I'll have to check with Bill Nye the Science Guy.
Jeanneau 54DS
coleman-stirling fridge/freezer rrgane Gear & Maintenance 12 02-01-2010 08:19 AM
Organizing the Lazarette bacampbe Gear & Maintenance 7 06-22-2009 10:14 AM
Separate freezer and fridge - two compressors or one? killarney_sailor Gear & Maintenance 7 07-30-2008 04:10 PM
Leaving fridge/freezer on for the season...? labatt Gear & Maintenance 4 05-28-2007 09:28 PM
Organizing the running rigging... need help and advice skrap1r0n Gear & Maintenance 11 04-24-2007 04:07 PM
