Heaving to.....what gives. - Page 2 - SailNet Community
 1Likes
post #11 of 22 Old 05-13-2011
Barquito
Barquito's Avatar
I think the most amazing part of the book is where they're heaved to in winds with sustained speeds of 80 knots (force 12) for two days, during which time the boat's turbulence actually becalmed the encroaching seas.
I think they also had a sea anchor out to keep the boat oriented the way they wanted. O/W the bow would probably get pushed too far down with each wave. I'm looking foreward to experimenting with heaving-to this summer. I had a swing keel 22' boat last summer, and a cut-away full keel 27' boat this summer.
Barquito is offline
post #12 of 22 Old 05-13-2011
AdamLein's Avatar
I need to leave some tension in the mainsheet to provide some weather-helm, or the boat will spin off downwind. If it starts to make headway after that, yes, the rudder will turn it into the wind, but that sets up a slow oscillation during half of which we are beam-on to the waves.
On the other hand, on my boat, keeping the main in too close means we slowly forereach with the rudder basically stalled.
s/v Laelia - 1978 Pearson 365 ketch
AdamLein is offline
post #13 of 22 Old 05-13-2011
travlin-easy's Avatar
In some instances they didn't put put a sea anchor or drogue, even it horrendous winds. When they did put out a drogue it turned out to be much more difficult to retrieve than the sea anchor. In the book they also did comparisons of sea anchors and drogues and showed methods of deployment that were pretty amazing. They talked a lot about triple-reefed mains, storm sails, and even sailing on the poles. The main point that made more sense than anything else is that it is very foolish to try and outrun a storm. In almost every instance, boats trying to outrun ocean storms were severely damaged, many crew members were injured, some were killed and there were a fair number of boats sunk. In boats that hove to, damages, if any were often very minimal, crew injuries were usually not severe or life threatening, and most of the time the storm blew itself out in a day or two at most. When you are trying to outrun a storm you are going in the same direction as the storm itself, thus exposing yourself and crew to longer periods of nasty conditions.
One of the neat things I discovered about their sea anchors was that most were war surplus parachutes measuring just 8 feet in diameter. And, the use of a trip-line was discouraged because it constantly wrapped around the chute lines, which eventually resulted in closing the chute.
Lots of information in the book, and like I said, it's one that should be kept onboard at all times as a reference manual.
Cheers,
Gary
travlin-easy is offline
post #14 of 22 Old 05-13-2011
Barquito
Barquito's Avatar
Being a day sailor, I have never been in a severe storm. I would imagine it would take a lot of confidence to 'stop sailing', and heave-to in a near survival storm. Just seems like my first instinct would be to keep actively managing the boat. Obvioulsly, this is why this sort of stuff should be practiced in more mild conditions first.
Barquito is offline
post #15 of 22 Old 05-13-2011
I agree. Try heaving to in winds of about 10 knots or less in an open area during mid day when you have lots of room around you. Learn the ins and outs of the procedure, then work your way up to somewhat higher winds with gusts. The question most often posed to the authors of the book is "When should I heave to?" The simple answer to this is "Before you think it's necessary to heave to."
Good Luck,
Gary
post #16 of 22 Old 05-13-2011
It's probably not necessary to point out.
While heaving-to can be a successful storm tactic, I regularly heave-to to set a reef in the main, it gives me a much more stable deck.
I use it, when I have room, to stop for lunch rather than break out the anchor. I'll heave-to on a starboard tack to maintain stand-on status ( a trick I learned here)
I heave-to, all the time to catch fish!! When a fish is on, I immediately heave-to leaving the fish to windward, and try to bring it over the beam.
I find It a useful tactic under many circumstances.
I would probably not heave-to in a short duration squall..I prefer to be more proactive.
tempest is offline
post #17 of 22 Old 05-13-2011
tommays's Avatar
Even the J24 does it well under reefed mainsail as we have done it during some big storms that passed between races
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #18 of 22 Old 05-13-2011
Tommays,
I teach on J-24's , They do settle in pretty nicely. I have to tweak it a bit because of the hudson river current, but once I get it tuned in they perform nicely.
I'm not sure why they are such a popular teaching boat with the sloped cabin top and tight cockpit ( for 5) But they are fun in a breeze.
tempest is offline
post #19 of 22 Old 05-14-2011
Omatako's Avatar
Whilst I am never going to suggest that I have superior experience or knowledge to the Pardeys, a few questions/comments on my own limited experience.
First question is when does "heaving to" become "lying to a sea anchor"? Seems to me the distinction has been lost in some of the examples given.
When does "running with" turn into "trying to outrun" a storm? I have only been caught in one bad storm (70 gusting 80 with 30 - 40ft, occasionally breaking seas). We sailed at 9kn under bare poles and the boat was threatening to surf, pitch dark, I decided to heave to. We got slammed by a huge broken wave (white water) and then by a wave that actually broke against the side of the boat with enough force to knock cabinetry off the walls.
So I decided to run at an angle to the weather and to slow the boat down with drogues to about 3 - 4kn. Using the age-old Ballot & Buys rule, we estimated the position of the storm centre then sailed away from it. It was that successful that this is now my stated policy on heavy weather management (with due respect to the Pardeys). I don't own a sea anchor.
Another thing that bothers me is when I watch systems moving across the Pacific to the immediate north of us, they sometimes take several days to move relatively small distances. In the infamous Queens Birthday storm north of New Zealand some years ago, boats were hove to and stayed in horrendous weather (80kn +) for three or four days while the system "parked" over them. Some of those boats were lost.
So like all things, heaving to is not the silver bullet that keeps one safe when things get really tough (IMHO).
Arthur C. Clarke
Omatako is offline
post #20 of 22 Old 05-14-2011
My O'Day 22(shoal keel/centerboard) heaves to very well with the main sheeted in(not luffing).
TSchwarck is offline
Heaving to StarJourney Learning to Sail 10 06-06-2010 01:27 PM
Heaving a cat rig? drobarge Seamanship & Navigation 4 03-17-2010 06:44 PM
Heaving To sailak Seamanship & Navigation 5 06-19-2009 10:50 AM
heaving to snoreky Learning to Sail 7 03-13-2004 11:28 AM
What Is Heaving-to? John Rousmaniere Seamanship Articles 0 10-05-1999 08:00 PM
