Ship it, Sail it, or Pay a Professional to Sail it? - Page 2 - SailNet Community
post #11 of 34 Old 05-14-2011
dhays's Avatar
Bluewatergirl, Sailing the boat north would be a great experience. If you really have the time and inclination to do it, can afford a delivery Captain to go with you, and can afford to make your new boat sea-worthy for the trip, go for it.
However, there is a lot to consider. The Oregon and Washington coast can be really nasty in bad weather. The problem is that if the weather is really bad, many of the ports on the coast can be impossible or too dangerous to enter. Given this, you need a good weather window.
My $10k estimate for shipping is just a rough guess. If you can yours can decommission the boat, then commission it on this end, you would save a lot of money. OTOH, you can easily get a quote from a local yard in SD as to what the cost would be to decommission the boat, and check with local yards and riggers here to do the commissioning. I could have done it cheaper, but time was a real issue for me and I decided to go with yards and riggers that I had a lot of confidence in. If I spent an extra boat buck in the process, it was worth it to me. You may be able to do it cheaper.
Dave
Dave
47⁰20'11.7" N
122⁰35'20.8" W
M/V Kinship, North Pacific 43
Formerly
S/V Legacy, Catalina 400 MkII, Hull #328
dhays is offline
post #12 of 34 Old 05-14-2011
TQA
Bombay Explorer 44
TQA's Avatar
One way of doing this trip and propably the way I would go if I had to sail it would be two long tacks.
Tack 1 San Diego to Hawaii
Tack 2 Hawaii to Pudget sound.
But I still think the I5 is favourite.
TQA is offline
post #13 of 34 Old 05-14-2011
Courtney the Dancer
jrd22's Avatar
I tend to agree with TQA, going north is a long uphill slog on the west coast. I haven't done it but if you look at prevailing winds and currents along the coast you are going to be beating into wind and waves all the way so you will probably be motoring, a lot.
The boat trucking companies are hurting so you should be able to cut a pretty good deal. My son got a quote of $9500 from NC to Anacortes, not including yard expenses at each end. It shouldn't be more than a thousand at each end of the trip. It is a lot of work to prepare the boat for transport though, you would want to be there and do it yourself if you choose this route. Everything has to be secured, and you should wrap winches, etc in plastic wrap and duct tape, and the entire mast should be bubble wrapped and plastic wrapped and cushioned with carpet rems where it contacts the trailer.
Don't underestimate the trip from SD to JDFuca, a lot of people have started and turned around after realizing that it's going to take forever (well, that might be an exaggeration:-))
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #14 of 34 Old 05-14-2011
Originally Posted by deniseO30 View Post
Denise,
Hell, here in the mid Atlantic area they've tried to convince me sailing Delaware bay is more life threatening then sailing up the Jersey coast.
Dear Lady,
It Is!
Bottom structure makes for some white knuckle wave heights and shapes.
Friend was on a 44' Pilot Boat that got slammed and wound up being spun around 180 degrees.
Dick
Flybyknight is offline
post #15 of 34 Old 05-14-2011
Originally Posted by BluewaterGirl View Post
I remember living with some oddballs in college and I had to grow up and adapt in order to make it work, so you may just have a point there. However, as a high school teacher, I am pretty adept at commanding some strong (and occasionally oppositional) personalities .
Thanks again everyone,
Denise
Adapting to an oddball or problematic personality in a college dorm where you can take a walk or go to a movie for a break is an entirely different thing from being literally trapped aboard the small space that is a boat at sea - even if it is your own boat.
The advice you've been getting from west coasters and other experienced ocean sailors has a pretty common theme. TQA's 'two tack' suggestion is not a joke (though you'll probably have to flip to port tack at some point on the second leg to lay Juan de Fuca - so it might be 3 tacks overall ) - or just do two tacks, explore Alaska and the BC coast on your way back to Puget Sound.....
We know two sets of friends that recently made that trip going South.. even that was cold and miserable (in July/August) until you get as far south as the California border. My own experience on a similar leg to Northern Cali in July was the same.
All the harbours between Juan de Fuca and San Fran are not foul weather entries - if/when you need the shelter most you won't be able to get in without significant risk. (Google 'columbia bar' for some insight)
I suspect that given the odds of waiting for weather windows and the generally slow progress heading northwest, the route via Hawaii may be just as quick, esp if you don't dawdle there (though why wouldn't you??)
Tough call.... it's going to cost you something either way. Best of luck.
Faster is offline
post #16 of 34 Old 05-14-2011
blt2ski's Avatar
SOme friends just bought a 49' Kroger? granted a power boat, ment for ocean work........but it is coming to Victoria BC via boat, ala a dry dock BIG boat, your boat floats on, the BIG boat drydocks, then away the boat goes. It was about the same as trucking, IRC it will be up here about late June or July.
Might look at that option, no rig decommissioning, Recommission up here etc.
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #17 of 34 Old 05-14-2011
Marty just reminded me... one of the couples I mentioned that went south a few years back are, as we 'type', placing their Passport 40 on a ship in La Paz to bring it back to BC. Having done the trip down, and deciding that ocean crossing was not on their 'to do' list, clearly sailing back home wasn't either.
Faster is offline
post #18 of 34 Old 05-15-2011
Sailing fool!!!
Send a message via AIM to headcaseracer
In my humble opinion, I would just plan well. I think you could do the trip by yourselves. Make two plans. One plan for everything going perfectly and one for if it all goes wrong. If the weather is going to turn ugly, then you have a backup plan. For example, I'm bringing a boat from Chicago to South Haven on Lake Michigan. I plan on making one stop, however, because it's an untested boat (and you are an untested crew), I know which ports are on the way that I can stop at, just in case. The nice thing about the Pacific is that it's fairly consistent. My wife and I have sailed quite a bit around San Diego all the way up to LA. We enjoy the Pacific. Hope for the best, plan for the worst and you'll be fine.
Headcaseracer
1979 Seidelmann 299
Cruising-Lake Michigan
headcaseracer is offline
post #19 of 34 Old 05-15-2011
SV Skalliwag #141
brokesailor's Avatar
I had a boat shipped from Kemah, Tx to Maryland two months ago. The boat is still sitting in the boatyard awaiting recommissioning. The quotes for getting the boat ready to ship was way off,or the selling broker just flat out lied to me, it cost twice as much to prep. The shipment cost me $5K and who knows how much recommissioning will cost me. I disagree with hiring a captain will cost the same as shipping. If I were you I would hire a captain and go with him. You will be a pro by the time you arrive at your destination.
brokesailor is offline
post #20 of 34 Old 05-15-2011
jimrafford's Avatar
We shipped our 40' sailboat from San Diego to Conn. last August. The shipping was about 10k, the yard bill in San Diego was about 2.5k, the yard did all the work, and about 1k on this end. I did most of the work when the boat arrived here.
You didn't mention the age of the boat and if it' new to you. Something to think about if this boat is new to you. My boat passed it's survey w/ flying colors and almost every system failed in the first month once we started using it here. I'm still working on correcting problems. systems failing offshore would turn the trip into a learning experiance you won't enjoy.
Jim
S/V Deja Vu
CS 40
jimrafford is offline
Tall ship gets ready to set sail (Times Herald) NewsReader News Feeds 0 06-05-2006 08:15 AM
Thalassography: Old sailing ship. @ Sail Blogs NewsReader News Feeds 0 04-19-2006 11:15 AM
The Voyages of the Good Ship Jabulani: Finally under sail @ Sail Blogs NewsReader News Feeds 0 04-18-2006 03:15 PM
HITMAN - Professional Killings (Get ahead in the sailing world) @ Sail Search Blog NewsReader News Feeds 0 04-17-2006 02:16 AM
Sail Ship skipperalex Crew Wanted/Available 0 10-05-2003 01:20 AM
