Harbor Freight trickle charger - Page 2 - SailNet Community
post #11 of 13 Old 06-12-2011
SailingWebGuy's Avatar
Originally Posted by travlineasy View Post
I can highly recommend the Pro-Sport-20 Plus Prosport Battery Chargers 20, Outputs, 12/24v, 20a Capacity
Gary
I second this. Excellent customer service. I had one go bad the day after I hooked it up. They sent a replacement out to me that same day and paid for the shipping to return the faulty unit. The new unit has been working great.
My complete refit is taking completely too long!
SailingWebGuy is offline
post #12 of 13 Old 06-12-2011
Old Fart
DwayneSpeer's Avatar
Don't use a trickle charger
Don't use any trickle charger. It will just cause your batteries to sulfate up and fail prematurely. Get a good three stage charger with the capacity to equalize the battery intermittently and keep it plugged in when in port. It will stretch the life of your batteries greatly. My house batteries (4 golf cart deep discharge batteries wired as 2 twelve volt banks) are over 8 years old and still going strong. I personally use the Xantrex 20 but any high quality one will do.
Hey, can one of you guys pass me a crab?
DwayneSpeer is offline
post #13 of 13 Old 06-13-2011
Going back to the original question, any trickle charger will "keep up" a battery against normal self-discharge.
"Don't use any trickle charger. It will just cause your batteries to sulfate up and fail prematurely." That's just not true. using a trickle charger to counter the normal effects of self-discharge is ALL that is necessary to prevent sulphation from normal self-discharge. Equalization and three-stage charging is all nice and good for batteries in use--but beyond the scope of simply maintaining a battery out of use for a couple of months.
HF is a good source for disposable tools, sometimes I buy them there with that purpose in mind, to do one non-critical job at a price. Only if I can take it back or throw it away without any injury or tears.
But considering how many house fires are started by "wall warts" and other little low-voltage devices...I'm not sure I'd want anything from HF plugged in long term while I slept.
hellosailor is offline
Harbor Freight Tools - Crimper Update Maine Sail Gear & Maintenance 132 05-03-2014 10:33 PM
Replacing Trickle Charger with 3 stage charger jasoncandace Gear & Maintenance 6 10-17-2010 07:27 PM
Sunforce trickle charger fordo Gear & Maintenance 1 05-24-2010 05:54 AM
Harbor Freight 316 stainless swageless fittings JProcter Gear & Maintenance 50 11-13-2009 08:13 PM
Trickle charger brak Gear & Maintenance 30 10-18-2008 12:02 PM
