Old 05-17-2011
Mauiwowie is on a distinguished road
Ignition Yanmar 2GM
I just purchased a 1974 Ericson 29 with a Yanmar 2GM. Is the ignition (push button) wired so the that the blower must be on?
Life should NOT be a journey to the grave with the intention of
arriving safely in an attractive and well preserved body, but rather to skid
in sideways, greasy fries in one hand, beer in the other, body
thoroughly used up, totally worn out and screaming "WOO HOO what a ride
Old 05-17-2011
denby's Avatar
Location: Dead Sea, some times called Long Island Sound
denby is a jewel in the rough denby is a jewel in the rough denby is a jewel in the rough denby is a jewel in the rough
Blower? Isn't that engine diesel?
Dennis
O'Day 302
Be careful or i will do what the voices tell me to do
To get the most from Sailnet, follow the link in
's signature.
Hey stuffit "Get a life"
Old 05-17-2011
Gary M's Avatar
Gary M is on a distinguished road
Diesels do not have ignition and do not require blowers. The push button causes the starter to turn the engine over. Compression and heat cause the fuel to burn.
I would suggest that it might be worthwhile to read up on diesel engines a bit. Yanmars are, in my experience, very dependable but you need to do the basics such as keeping your fuel filters clean and making sure you get quality fuel.
Good Luck
Old 05-17-2011
Yes, so blower is not even needed???
Old 05-17-2011
JimsCAL's Avatar
JimsCAL is on a distinguished road
Suspect the boat was repowered from a gas engine (Atomic 4?) at some point. Diesel doesn't require the blower.
Old 05-18-2011
October Moon B43
MJBrown is on a distinguished road
The blower is used to take heat out of the engine compartment and surrounding areas. Unless you want to warm up your boat and possible encounter issues due to excessive heat I'd keep it so it runs when the engine is on.
Old 05-18-2011
Agree with MJBrown... while diesels do not really require the blower like a gas engine does, having one left over from a repower, or adding one, is a good idea as it an remove residual heat and smell of a running diesel.
Recent Beneteaus have installed a blower that runs whenever the engine runs on their diesel powered boats. I'm considering adding one to our boat too.
1984 Fast/Nicholson 345
Old 05-18-2011
capttb is on a distinguished road
While not required I believe most builders put blowers on diesel powered boats, I know Catalina does and always has to best of my knowledge. While usually powered by the same circuit as the instrument panel it doesn't need to be on to start the engine. Is that the OP's question or am I confused again?
The 70's Ericson did not come with a diesel so this blower is probably from the A4 and could be wired whatever way looked good when it was repowered.
"Democracy is two wolves and a lamb deciding what to have for lunch, Liberty is a well armed lamb contesting the decision."
Old 05-18-2011
Mahalo,
I will keep the blower.
yanmar ignition key arman Gear & Maintenance 10 05-16-2011 06:28 PM
ignition QuickMick Atomic 4 15 02-10-2011 04:14 PM
spotty ignition QuickMick Electrical Systems 3 07-09-2010 09:56 AM
Ignition Problem.. kyoufu Gear & Maintenance 13 08-04-2008 07:48 AM
saildrive ignition cut out atk260lq Gear & Maintenance 1 06-19-2008 08:36 PM
