05-24-2011
Chastened
4 days for 4 thru-hulls when you've never done anything like this might be pushing it, but it's not rocket surgery.
There is a link from one of our contributors (Maine Sail) that gives the procedure in detail, with full color, glossy, 8X10 photos and arrows and all sorts of jazz. I can't access it from work so hopefully someone will post it up.
There is no "thru-hull specifically for a Paceship". You just measure the size and buy the same sized replacement. If you want to enlarge the hole and buy a bigger mushroom and seacock, go for it. Just remember, if the thru-hull or seacock fails, then you'll have that much more water rushing in.
S/V Old Shoes
1973 Pearson 30 #255
