Old 05-25-2011
Christoponeal is on a distinguished road
Missing jib/genoa sail PLEASE HELP
I am extremely new to sailing. I bought a boat yesterday for very cheap. It's in good shape but after a little research, I noticed the I am missing the front sail. Does anyone know how to figure out which sail I need or maybe someone has one lying around. The only info have have on the boat is the tag that reads-
Anchor Sailboat
Div. Molded fiber glass body Co.
Union City, Pennsylvania
Class - Pintail
Serial no - 502-97
The LOA is 14' 3" and the main sail is
Leech- 203" or 16.91'
Foot- 101" or 8.41'
these measurements are overall measurements not grommet to grommet
Any information would ve greatly appreciated.
Old 05-25-2011
UPHILL's Avatar
UPHILL is on a distinguished road
This is what I found on the Pintail.
PINTAIL Sailboat details on sailboatdata.com
Catalina 25 1984 #4558 Swing Keel, Tall Rig
Sailing Payette Lake, Central Idaho USA
_______________________________________________
Old 05-25-2011
Thanks for the speedy response. I found this page as well, the problem I have having is the dimensions listed for the main sail do not match my main sail. How do I know if I need a genoa or jib? Do the measurements have to be exact or will it work as long as it's close?
Old 05-25-2011
HDChopper's Avatar
Needing Apehanger Helm
HDChopper is on a distinguished road
Or Chris your mainsail may not be the correct one .. just a thought.
There is no right way to do the wrong thing
Old 05-25-2011
JimsCAL's Avatar
JimsCAL is on a distinguished road
If you can find a class sail used great. If not, measure the length of the forestay. And sail with luff somewhat shorter than that will work. I am assuming this is a hanked on sail.
Old 05-25-2011
SEMIJim's Avatar
Last Grumpy Old Sailor
SEMIJim will become famous soon enough SEMIJim will become famous soon enough
Originally Posted by Christoponeal View Post
... the problem I have having is the dimensions listed for the main sail do not match my main sail.
How far off are they? Could it be that the main is just old and stretched-out?
One could argue you need both
A "jib" is a foresail that's 100% or smaller, and a genoa is a foresail that's greater than 100%. "100% of what?," you might ask. Well, 100% of the distance from the tack of the sail to the mast of the boat. If the foot reaches just to the mast: It's a 100%, aka: "Working jib", aka: a #3. Your largest foresail, most commonly 150-155%, would be a #1 genoa. If you have a #2 genny, it'll usually be in the range of 125-135%.
Sometimes people have bigger #1s, in the vicinity of 160%, up to even 175%. (Those are called "deck sweepers.")
A #4 jib will usually be in the vicinity of 75-80%. Lastly comes the storm jib, usually at about 25%.
Most boats make do with a #1 and #3.
We ended-up with four #1s. I'm going to see if one of them can be cut down to a #2, or possibly even a racing #3.
Jim
s/v Abracadabra
1976 Pearson P30
Old 05-25-2011
Thanks for all the input everyone.
I considered that my sail may not be Original. The dimensions on the webpage I found for the main sail is
Leech - 18 ( mine is 16.91 )
Foot - 8.92 ( mine is 8.41 )
I'm not sure that the size called out would even fit on my boat.
Also, I just measured my boat and 100% jib foot is roughly 4 1/2'. The website was calling out a 6' foot on the jib. Is a pintail a model for several manufactures or should all pintails be the same? Sail searching is a pain, but I like the challenge. Suppose I had one custom made, how would I figure out how high up the mast for the leech?
Old 05-25-2011
SEMIJim's Avatar
I guess you'll have to calculate the luff. Then measure the distance from the gooseneck to the sheave at the top of the mast. It should be a bit more than the mainsail's luff. Measure from the gooseneck to the end of the boom. Again: Should be somewhat longer than the foot of the mainsail.
Sounds like it came with a 133% genoa.
Jim
s/v Abracadabra
1976 Pearson P30
Old 05-29-2011
sonosail is on a distinguished road
Jib measurents for Pintail Class
I'm not sure where you saw the sail dimensions that you were speaking of.
Here's something that I had lying around for this particular boat.
No matter what the diagrams say, make sure to take an accurate measurement of you forestay, (jib hoist). According to what I see here, it shouldn't be any LESS that 13' 6". These measurents SHOULD place the jib clew in it's proper position, (allowing it to trimmed using the standard hardware.) But it's ALWAYS best to check this also. Best of luck.
Hope this helps.
Randy Browning
sailboatdata.com
Missing jib/genoa sail-pintail_jib_diagram.jpg   Missing jib/genoa sail-pintail_genoa_diagram.jpg
Randy Browning
Norwalk, CT USA
sailboatdata.com
Full price for a second hand main sail and genoa for Fountaine Pajot Venezia 42 Ricardomust1970 Gear & Maintenance 11 09-02-2010 05:08 PM
main sail from genoa sailbot Gear & Maintenance 16 04-08-2008 12:20 PM
Sail boater missing in bay of Green Bay - WKBT NewsReader News Feeds 0 06-11-2007 06:15 PM
Sail boater missing in bay of Green Bay - WBAY NewsReader News Feeds 0 06-11-2007 03:15 PM
Missing man warned not to sail (San Jose Mercury News) NewsReader News Feeds 0 11-13-2006 06:15 AM
