05-26-2011
Originally Posted by Nautichthys
I'd be careful about using these sites for real time navigation. In the area I hang out in there can be quite a lag between position updates. For example, marinetraffic.com is showing one ferry between Vancouver and Nanaimo at its position 45 minutes ago, and the Gabriola ferry in the wrong dock, where it was 35 minutes ago.
The sites vary in what they pick up as well. Marinetraffic.com is showing three transponders in Nanaimo Harbour, Login is showing eight, and the Gabriola ferry is on the right side of the harbour for this time of day. One of the transponders marinetraffic.com isn't seeing is on a 1200 tonne Class A.
Marinetraffic.com very rarely shows my Class B transponder. AIS3 usually picks it up but I've seen both sites miss a lot of Class B traffic around the Saanich Peninsula.
Regardless, very nifty sites.
I've been playing with the Android app for marine traffic and this mirrors my experience. If you see a target that could present a problem you can give the app a check to see if its showing, but reality trumps what the display shows.
Latency in my area of the Chesapeake Bay seems to be on the order of 5-10 minutes, so even at 15-20 knots you can usually identify a target correctly.
PalmettoSailor (formerly midlifesailor)
s/v Palmetto Moon
1991 Catalina 36
