  #21
Old 05-27-2011
EJO's Avatar
EJO EJO is offline
Dutchman
EJO is on a distinguished road
smallboatlover get some PVC (sewer) pipe at the Do-It-Yourself store, cut it to the length you can fit all you stuff in , glue-cap one end and use a "clean-out" type screw end on the other side. You can do this with 2" to 6" diameter pipe. Much cheaper solution than "dry bags" (with the exception of garbage bags) and you can then bungy/store it in one of the forward holes or latch it to the mast. After you do that you can enjoy the sailing as it should be done in a boat like yours. Like Don1500 said you have to find the edge which is so much fun in a smaller boat/sailing dinghy.
Go out have fun stop worrying.
Skipper E-J
S/V "Sailmates" 1973 IRWIN 32 Classic
I want to live and sail forever, so far so good[/SIGPIC]
  #22
Old 05-27-2011
MarkSF is on a distinguished road
Originally Posted by Boasun View Post
Stay close to shore on a hot day and deliberately plunk the boat over and right it. Just be sure that there is more water under the boat than the mast is long. Rotate all of your family through this drill as the person in charge.
This way you will see what comes loose and starts to float far far away from you.
NOOOOO!
Take a look at these pics. Mistral 16 sailboat for sale You can see that the boat has a cover over the aft compartment that is missing from this boat. Now I've not had Mistral a but I am familiar with the boat it's cloned from, the Wayfarer. The Wayfarer's aft compartment is crucial for buoyancy. In fact they won't let you race unless you have had a leak test done on the aft compartment.
I also believe that the forward compartment should have covers on the inspection holes and shouldn't have a hole drilled in it for a spinnaker pole unless it's a sealed tube! Again the forward compartment is partly for buoyancy. My Wayfarer had a couple of inflated beach balls in the forward compartment as a cheap buoyancy measure.
On later Mk II Wayfarers they added some foam between the floor and the hull giving them some intrinsic bouyancy but a notorious tendency to turtle. This Mistral looks like a Mk II clone. Most Mk IIs have added sailtop bouyancy, a small inflatable bladder in the top of the sail or similar. I added this to my Mk I.
So before deliberately capsizing it I would :
Investigate the designed buoyancy measures on your boat and restore compartment covers if they are indeed necessary.
Get sailtop floatation.
Even then I would do it first in a lake with a second boat standing by to assist.
  #23
Old 05-27-2011
the "NEW" guy...
SlipperySkipper is on a distinguished road
Originally Posted by CapnBilll View Post
Westmarine sells a storage locker with a hinged door, has an O-ring seal and watertight latch.
+1 these are pretty sweet!
no gas, no problem.
  #24
Old 05-27-2011
smallboatlover's Avatar
Huck
smallboatlover is on a distinguished road
thats what i thought about the aft compartments the look like they were put there after the boat was made. so i won't capsize the boat untill i get a water proof seal on the forward cubby and the spinnaker hole idk was to do about that.
16' mistral sailboat, And 27' coronado
You may post attachments
You may edit your posts
This may actually happen! JudOWNED Introduce Yourself 3 03-20-2010 10:18 AM
It can happen bubb2 General Discussion (sailing related) 63 11-14-2009 10:29 AM
So what do you think would happen davidpm Seamanship 29 05-22-2009 10:15 PM
Could you let this happen to yours? Faster General Discussion (sailing related) 44 01-07-2008 08:07 PM
SEO by vBSEO 3.6.1
