Request Experienced Sailors - Page 2 - SailNet Community
post #11 of 16 Old 05-26-2011 Thread Starter
Blue Horizons
Harborless's Avatar
Okay thank you! A few questions:
The boat owner manuel shows two seacocks even though it shows four thru hulls. Also, under the sink in the head a hose is attached to what appears to be direct to the thru hull.. Do I need a seacock there or is this arrangement safe?
Also, Are you saying I CAN or CANNOT install dorades there then? Or should I just stick to solar vents?
Lastly, The portholes are structurally unsound and leak and so need replacing. Also, I do need more ventilation and none of the four in the main cabin open up.
Harborless is offline
post #12 of 16 Old 05-26-2011
Any through-hull fitting that is below the waterline should have a proper seacock fitted. Sounds like your sink drain should too, unless the outlet is above waterline.. but even then.......
Faster is offline
post #13 of 16 Old 05-26-2011
tommays's Avatar
The sea-cocks are gate valves with what looks like Grey PVC screwed into the valve
Both of those things are kind of kiss of death items as the gate valves tend to not work and the PVC cracks real easy
I showed a picture of one my upgraded sea-cocks so you could see the difference
no reason you cant do the boxes the PO of my boat built nice beefy ones with hand holds and the really do a great job of venting the boat
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #14 of 16 Old 05-26-2011
The proper dorade box as shown above works like this:
if you simply install a cowl vent like this:
...any water getting in will go straight below. You're probably better off trying to seal the lenses of those portlights and appreciate the light below. Dorade boxes on the foredeck aren't really the right place anyway, if that's where they are...
Faster is offline
post #15 of 16 Old 05-26-2011 Thread Starter
Blue Horizons
Harborless's Avatar
I decided on the Niko stainless steel solar vents. I will install two and have the fans blowing opposite directions.
My boat owners manuel has the dimensions for the two seacocks listed. How should I measure the replacement seacock for the engine compartment and figure out how big I need for the head too? The two seacocks listed are 1 1/2" and 1/2" respectively width wise.
Tommorow I want to redo my forward hatch. It leaks and the port hinge is rusted and the sealent is all but gone. I have been looking all over for a step-by-step on how to repair a deck hatch but with no luck.
I would think I just unscrew it. Replace the hinges and rebed them- check for water damage from the rusted one and make any repairs first. Sand down the hatch, fill in the stress cracks, scrape off all old sealent and apply new then just rescrew on the hatch--- pretty much the jist?
post #16 of 16 Old 05-27-2011
Boasun's Avatar
No matter which vent that you install, Dorade or the other. There should be an easy way, from below decks, to secure them for heavy weather. In other words seal them up water tight. Thus if you happen to be caught out in foul weather, you can secure your vessel for boarding seas. Yes it does happen and it will only be about less then 5% of the time you spend sailing. And if you are really in favor of the weather Gods it will be never. But they do love to hassle the ill prepared sailor.
1600 Ton Master, 2nd Mate Unlimited Tonnage
Maritime Instructor
S/V Rapture
Boasun is offline
New sailors request help -- catalina 27? rconn2 Boat Reviews 26 10-18-2010 09:05 PM
Just a question for experienced sailors sailguy40 Learning to Sail 23 03-04-2010 11:18 PM
Re: Connecting Sailors to Sailboats / or Sailors to Sailors NewsReader Mass Bay Sailors 0 05-25-2007 01:15 AM
Advice from Experienced sailors! D3AN Learning to Sail 15 07-31-2006 09:09 AM
