Is this boat worth saving? - Page 2 - SailNet Community
post #11 of 19 Old 05-31-2011 Thread Starter
dylanwinter1's Avatar
boat aesthetics and inboards v outboards
Oh , so the thing is called a SeaWych. Sorry but they are ugly. The Slug may well be aptly named but she has pedigree and looks the part. Drop the diesel overboard and get a four stroke.
not many bilge keelers look good out of the water
the fact that I can sail the slug is 2 feet of water is a great bonus
The inboard has been wonderful
Its true in flat water where the prop can be working at a reasonable depth to deliver everything it has got to give to the boat and outboard can push any boat along at a good speed
It also has the advantage of being off to one side so it is firing all its power away from the boat.
The slugs prop is right under my feet - in front of the tiller
That has two effects - first there is some loss of forward power because the flow from the prop runs into the rudder - no idea how much it is but it must disrupt the flow
the upside of that is that when you want the boat to respond to the tiller - it does it
Then the prop on the slug is big - much bigger than an outboard prop
it is turning deeper in the water - with all that weight of water above it to make it more effective
and it is sweeping a bigger area of water - but moving it more slowly
when a wave tries to push the slugs bow out of line then the rudder working in the flow from the outboard delivers that turning motion.
I have tried pushing through big waves with an outboard - it was not very satisfactory
I know that an outboard on the back of the boat will sometimes require me to place my hands on both the outboard and the tiller to vector it
I sail single handed - so coming into quays needs to be done slowly and under control. Onre hand for the tiller, the other for the mooring lines
The turning prop is well out of the way of errant lines - all my mooring lines are bouyant
In my opinion there is no doubting that the advantages of an inboard are massive when it comes to single handed sailing and safety in a small boat.
But.... keeping an old one going is stupidly expensive
so I really would like to keep the inboard
However,
I have now had the first assessment and guess at a price for fixing it from the engineer in Wisbech
the first email, which was a long one ended with
"I am sorry the news is not good
Robin Dunn"
the second email, which was much shorter ended with
"I am sorry the news is bad
Robin Dunn"
I wil put the emails on my website if anyone is interested
Dylan
dylanwinter1 is offline
post #12 of 19 Old 05-31-2011
Once known as Hartley18
Classic30's Avatar
Dock
Dylan, methinks you are over-estimating the issues using an outboard amd trying to talk yourself out of it.
..particularly this last statement, 'coz coming into a quay is far easier with an outboard, since the controls are right next to the tiller, not somewhere you have to reach down to!! (I'm presuming you don't have three hands here - one for the tiller, one for the mooring lines and one for the engine controls! )
Why don't you try it for a bit. See if you can beg/borrow/rent a long-shaft 4-stroke outboard for a little while and give it a go. Yes, it will be a challenge in rough seas, but someone with your experience should be sailing then - and think of all that extra space you'll get under the cockpit!!
Classic30 is offline
post #13 of 19 Old 05-31-2011
tdw
Super Fuzzy Moderator
tdw's Avatar
Hmmm... I'll go have a look a the site but I'm tneding to agree with young Cameron on this.
My proviso would be that I hadn't thought that Dylan and de Slug would be motoring at sea despite of course having seen you doing it on your vids. Dumb fuzzball. However, you were motoring in calm conditions.
Anywho .. off to check up on website emails.
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
post #14 of 19 Old 05-31-2011
djodenda's Avatar
Dylan... Forget about the boat, but keep the name. Kyrie is the best name for a sailboat ... ever!
David
1987 CS 36 Merlin "Kyrie"
djodenda is offline
post #15 of 19 Old 05-31-2011 Thread Starter
thanks for your input
wells bar - take a look
vlog 100 Wells to Wisbech « Keep Turning Left
I don't think it would be possible to sail through the bar no matter how experienced you are
and it would certainly have an outboard cavitating
the channel took me at right angles to the breaking waves
and wells is far from exceptional
there is one other factor... and that is battery charging
in my experience few outboards can do much for keeping pace with current demand for charging cameras and the laptop
winter sailing with an outboard would also be tougher
the beast really helps to keep the cabin dry - which is how I am able to look after the welfare of the cameras
I would not be able to run the proper HD cameras in the winter - keeping the moisture out of them would be really tough
I need to think it through pretty carefully - there are a lot of repercussions
post #16 of 19 Old 05-31-2011
Classic30's Avatar
Dock
Finally you've posted some serious arguments...
What sort of shape is Ugly's engine in? Any chance you could you swap engines without the current owner noticing??
post #17 of 19 Old 05-31-2011
tdw
tdw's Avatar
To quick for him. Not posted yet.
― Terry Pratchett.
tdw is offline
post #18 of 19 Old 05-31-2011 Thread Starter
The beast is in great shape
the volvo is in great shape
the SeaWych has no engine
the project has run into problems before and there will probably be more
I did not see this one coming though
the engine was running better than it ever had
I thought my engine problems were behind me
Dylan
post #19 of 19 Old 05-31-2011
tdw
tdw's Avatar
Good lord !!
OK so the diesel and its lovely big propellor and low down grunt stays.
Hey Dylan, why not post emails here instead of the site. I want to know what the engine story really is. My thought was that you just had a problem with engine mounts. I didn't think that would be ruinously expensive to do, esspecially with such a small donk. Obviously I am misssing part of the puzzle.
― Terry Pratchett.
tdw is offline
1. Dufour 27 2. How do you know how much a boat is worth? northoceanbeach Boat Review and Purchase Forum 4 07-24-2009 10:56 PM
Newport boat show worth it? toben General Discussion (sailing related) 5 09-16-2007 12:02 PM
Beachcat Sailing Series at Fort Worth Boat Club, Fort Worth, TX (The Beachcats) NewsReader News Feeds 0 02-12-2007 03:15 PM
Gift Boat--Worth it? Tikimama Boat Review and Purchase Forum 7 08-04-2003 11:07 AM
Buying first boat - what''s it worth Ace028 Boat Review and Purchase Forum 6 03-25-2003 07:10 AM
