Old 06-04-2011
brownlie88's Avatar
brownlie88 is on a distinguished road
Waterproofing inside a wet wooden hull
G'day all
I've recently purchased a 'fixer upper' a 28ft yacht, im not entirely sure what it is, i'll post pics and maybe someone can say.
However my first job is to waterproof the hull, currently it is completely empty and it taking on water, about an inch per day. What I want to do is paint the entire inside of the hull with something to make it waterproof, however.. I cant take the boat out of the water, so the wood I will be painting/waterproofing will be a little damp.
I'm wondering if tar would be an option or if there is an epoxy that could dry and seal in these conditions.
Any help would be great, thanks
Waterproofing inside a wet wooden hull-img_0387.jpg   Waterproofing inside a wet wooden hull-img_0388.jpg   Waterproofing inside a wet wooden hull-img_0393.jpg   Waterproofing inside a wet wooden hull-img_0390.jpg   Waterproofing inside a wet wooden hull-img_0394.jpg
Old 06-04-2011
JimsCAL's Avatar
JimsCAL is on a distinguished road
I doubt there is anything you can "paint" on the inside that will help. Was the boat just launched? If so, the leaking may slow or stop as the wood swells. If its been in the water for some time, the only solution may be hauling, drying the hull out, and recaulking.
Old 06-04-2011
brownlie88's Avatar
It was relaunched three years ago.
Old 06-04-2011
Quickstep192 is on a distinguished road
You may want to go to the Wooden Boat forum. To my knowledge, there's nothing that can be applied from the inside that will seal her up. If you can pump it dry, you might get a lead as to where the water is coming in. If it's just generally weeping in between the planks, chances are it needs to be re-caulked which can only be done from the outside.
Old 06-04-2011
Siamese is on a distinguished road
Somebody on this forum really ought to tell you. Might as well be me.
If you're asking about a paint to coat the inside of a wooden hull to keep it from leaking while it's in the water (or anywhere!), you should not be the owner of a wooden boat.
There are some extremely good reasons why 99.999% percent of pleasure boats are made of fiberglass. Unless you have an absolute love for wooden boats, combined with thorough knowledge of their repair, OR, vast financial resources, wood is a poor choice in 2011.
Sell.
Old 06-04-2011
WanderingStar is on a distinguished road
An inch a day isn't bad at all. I wouldn't worry much. There are several reasons she might leak. She might need caulking, or refastening. it might only be one seam or joint. If she doesn't leak dangerously under sail, and only pumps a couple of times a day (you have an automatic bilge pump, right?), don't worry. But no, you probably can't stop it by painting the inside.
Where are you located?
Old 06-04-2011
JoeDiver's Avatar
Catalina 25 Jockey
JoeDiver is on a distinguished road
If your boat is sinking (however slowly) you need to haul it out and fix it.
1982 Catalina 25 #2897
FK/SR/Traditional
Eagle Mountain Lake, Texas
Old 06-04-2011
Flybyknight is on a distinguished road
Rock Salt, lots and lots; like enough to cover any and all wet areas.
I'm serious.
That will prevent dry rot, your biggest enemy.
Dick
Old 06-04-2011
brownlie88's Avatar
Thanks for your replies. Does anyone know what sort of boat this is?
Fabric/Material for inside of hull (walls) GraemeInCanada General Discussion (sailing related) 12 03-17-2011 10:38 AM
Building Custom Foam Insulating Batts for Inside the Hull Bene505 Gear & Maintenance 9 01-17-2011 12:50 PM
Painting inside of Hull weephee General Discussion (sailing related) 8 08-30-2009 12:54 PM
Wooden Hull Seepage(Carvel question) jorjo General Discussion (sailing related) 3 08-12-2006 01:07 PM
Waterproofing Bimini trantor12020 Gear & Maintenance 12 06-26-2006 08:45 PM
