Swivel Shackle or Not? - Page 2 - SailNet Community
post #11 of 17 Old 06-09-2011
Omatako's Avatar
I've never used one before, don't use one now and probably never will. And my anchoring is not something I worry about now. It may be if there's a swivel in play.
It's an additional expense I can do without.
Arthur C. Clarke
Omatako is offline
post #12 of 17 Old 06-09-2011
Mermaid Hunter
SVAuspicious's Avatar
If you bring your anchor up at a measured pace, any twist in the chain will have a chance to unwind as you spray our glorious Chesapeake mud off. *grin*
My last boat had a swivel that came with the boat. My current boat doesn't have one and I don't miss it at all. Fewer pro's than con's in my mind.
SVAuspicious is offline
post #13 of 17 Old 08-13-2013
Re: Swivel Shackle or Not?
I'm just off the phone with Lewmar tech support, because I've been having troubles with my new anchor rode (50' chain, 200' rope) jamming on retrieval. He highly suggests the swivel, because the rope wants to twist (or untwist) as it gets paid out or pulled back. That all gets "pushed down the line" to the chain, and the anchor has way too much inertia to be spun around so the twisting gets bottled up in the chain.
From that advice I think I'm going to go ahead and add the swivel, sizing it as large as I can to attach to the chain. I may just keep it on there for a while, in hopes that the twists inherent in a new rode all smooth out over time. (For now we're just in San Francisco Bay; we're upgrading things before the big cruise.)
sierradave is offline
post #14 of 17 Old 08-13-2013
Old as Dirt!
svHyLyte's Avatar
If you are determined to add a swivel, use a short length of chain between the anchor and the swivel such that the swivel cannot be subjected to side or prying loads, which are a major contributor to their failure. Using "Brait" rather than 3-strand eliminates the issue of twist in rope rode; and, takes less space in one's chain locker.
FWIW...
svHyLyte is offline
post #15 of 17 Old 08-13-2013
If you're having a problem with 'twist', I'm assuming we're talking about 3-strand rope, no? In that case, it's a bit surprising to hear such a recommendation from Lewmar...
Because, the use of a swivel with 3-strand rope will allow the rope to begin to 'unlay' under extreme loads... Not likely to be a problem in ordinary anchoring scenarios, but I certainly wouldn't want to head off on your big cruise with such a setup...
HyLyte is right, if you're gonna be using a mixed rode, brait is the way to go...
Next time you're out sailing, you might try trailing your rode behind you for awhile, might be a short term solution to eliminating some of the twist in your new rope...
JonEisberg is offline
post #16 of 17 Old 08-13-2013
HANUMAN
RobGallagher's Avatar
I had an oversized swivel shackle on my rhode. When I transferred it to my new (to me) boat with an anchor roller I found that it created more problems than it ever solved.
My mooring does have a huge swivel, but that's semi-permanent so it needs one.
HANUMAN
'88 C&C 30 MKII
NOANK, CT
RobGallagher is offline
post #17 of 17 Old 08-14-2013
Scurvy Dog
Reef33's Avatar
Question Re: Swivel Shackle or Not?
Since we're on the subject of swivels, does anyone have an opinion on whether to use an eye-to-eye or an eye-to-jaw type swivel on a mooring chain? I had read somewhere that someone did not recommend using the eye-to-jaw type, but they didn't give a reason.
If you use the eye-to-eye type then you have to use an extra shackle, so I don't see the benefit of doing that. I actually can't see a reason to not use a jaw-to-jaw swivel and eliminate the extra shackles altogether. Thoughts?
Scourge of the Upper Chesapeake since 1993.
Reef33 is offline
What type of shackle to use on a halyard EXS2 Gear & Maintenance 19 11-03-2012 12:03 PM
Three shackle tether clancy11 Seamanship & Navigation 2 03-19-2011 10:04 AM
Bent mainsheet shackle (pictures included) CaseyJones Gear & Maintenance 8 09-26-2009 10:19 AM
Corroded Shackle dhornsey Gear & Maintenance 18 01-12-2009 09:04 AM
Opinion on Wichard Quick Release Shackle? labatt Gear & Maintenance 3 07-16-2007 01:25 PM
