Old 06-08-2011
Gusnyc is on a distinguished road
"Correct" side to sit in a dinghy?
Hi, the other day a friend of mine, gave me a hard time because I sat on the starboard side of my dinghy (Zoom, 8.6 ft). I sit on that side because I am lefty, and it feels much more comfortable to grab the tiller of the engine with my left arm. Also, the gear switch is facing the starboard side, so I can reach it and see it directly.
My friend gave me first a bad look about sitting on the starboard side. Then he told me that the correct way was was to sit on the port side (even when it was much harder to change the gears). He said that I will have "problems in the future" if I sit on the starboard side, but he didn't explain what kind of problems. He said that "if I would know what I am doing, I would be sitting on the port side, not on the starboard".
I couldn't find anything online about the "correct" side to sit on a dinghy. Another friend told me that I should sit wherever I feel more comfortable.
Is there a right side to sit on an inflatable Zodiac 8.6ft with a Tohatsu engine?
Thanks for your comments.
Gus
Old 06-08-2011
SecondWindNC's Avatar
SecondWindNC is on a distinguished road
You should sit wherever you're the most comfortable and have the most control, I would think.
Carolina Wind Yachting Center Charter Manager
Who is staring at the sea is already sailing a little.
Old 06-08-2011
nolatom will become famous soon enough
I am used to rigid dinghies and runabouts with single outboard, not so much inflatables where you're sitting on the inflatable "rail" on either side.
Only difference I can see besides accessability of the shift lever, is prop rotation and torque. A right-hand prop motor (I think most outboards are righties?) will want to turn to port with little force but turning motor and boat to stbd takes more force. This same prop side-force and rotational torque will heel you to port, I'd think. If so, sitting on the starboard side would seem better, it keeps you on the "high" side.
Unless I have this all backwards ;-) It's easier to tell if you're in the boat than at a keyboard, then you can feel the forces.
Me, I tend to sit on the middle of the midships thwart directly ahead of the motor in order to not heel the boat and not bury the stern with my weight , so the question of which 'side' doesn't really present itself.
Old 06-08-2011
Part of the solution
bljones has a spectacular aura about bljones has a spectacular aura about
Ask your friend to explain why every inflatable with a wheel and remote throttle is starboard oriented, unless it is a center console. The ask him to show you an example, just one, of a port-oriented dinghy. Then ask him to shut up.
It's 5 o'clock somewhere:
Old 06-08-2011
tomperanteau's Avatar
Crotchety Old Member
tomperanteau is on a distinguished road
Never heard of this. Sounds more like telling your buddy to run to the hardware store for a gallon of stripe paint or a left-handed screwdriver. Back when I was becoming an engineer, the joke was telling the noobs that you needed a gallon of grid-leak bias.
Capt'n Tom Living Aboard 50/50
S/V Footprints
1969 Crealock/Columbia 36 Sloop completely refitted in 2000 and new Yanmar in 2006.
Hey, if I can't be sailing at least I can be here!
Old 06-08-2011
Boasun's Avatar
Boasun will become famous soon enough Boasun will become famous soon enough
It is the side where you feel the safest and have the most control of your dink.
But you want to believe him. I have a couple of cans of Relative bearing grease I can sell you.
1600 Ton Master, 2nd Mate Unlimited Tonnage
Maritime Instructor
S/V Rapture
Old 06-08-2011
Yeah, but in an emergency there's no substitute for Danger Bearing Grease...
Old 06-08-2011
SVAuspicious's Avatar
Mermaid Hunter
SVAuspicious is on a distinguished road
Gus,
Your buddy is a moron.
respectfully, dave
sail fast and eat well, dave
S/V Auspicious
AuspiciousWorks.com
beware "cut and paste" sailors.
Old 06-08-2011
Believe me Boasun when I say that I don't want to believe him. He made me feel so ignorant about this (and everything else) for a whole weekend to the point of becoming traumatic.
I am a newbie in the sailing world, I've been having training with captains since last year (plus the ASA plus the Power Squadron). I don't feel that I am "experienced", but I can definitely handle my boat. Everything I did was wrong for him, including this dinghy situation.
Another remarks were: "You can never have the halyard too tense" (in a furling mast). "The west and east channel of Roosevelt Island (NYC, East River) are the same, it doesn't matter which one you take", etc, etc, etc.
I feel vindicated.
Old 06-08-2011
RichH's Avatar
RichH will become famous soon enough
All depend on which way the prop is turning and the amount of 'torque' produced by the engine.
A right handed prop (turns clockwise when looked at from the stern) can 'twist' the boat due to it torque so that the portside of the boat will be higher than the.starboard side .... IF the there is enough 'torque' being generate to do this. A boat with a right handed prop will typically have the 'steering on the starboard to compensate for this torque. To correct for this 'torque' one sits on the starboard side to keep the boat 'level' ... or the mfg. puts the steering wheel on the portside or 'left' side. .... and vice versa with a left handed prop - one that turns counter clockwise when looking from the stern .... steering wheel goes on the starboard side or 'right' side.
.... and this is the reason why some steering wheels are on the left side or right side of a high speed power boat - torque being generated by the prop ... and the wheel is positioned so that the weight/mass of the 'steerer' helps to keep the boat level (with respect to athwartship level).
On a dinghy there certainly isnt sufficient engine torque to make a difference ... so sit anywhere you want to and based on your 'comfort', etc.
Your friend is probably an obsessive 'control freak' and a rigid 'rule follower' ... but doesnt know 'why'. ;-)
the correct prop. exfus55 Gear & Maintenance 7 05-23-2009 04:48 PM
Can you tell me if this installation is correct? moonie5961 Gear & Maintenance 11 03-15-2009 04:19 PM
How do I correct a lee helm? samsciacca General Discussion (sailing related) 10 08-20-2007 08:28 PM
Correct forestay diameter? wysiwyg Gear & Maintenance 8 04-15-2007 06:02 PM
Correct Voltage Tom Wood Gear and Maintenance Articles 0 01-03-2002 07:00 PM
