Old 06-10-2011
micheck is on a distinguished road
Stuff on the mast head
My mast head is getting crowded - how do you mount:
VHF whip
windex
wind speed sensors
lightning rod/dissapator
halyard sheaves
stay mountings
Old 06-10-2011
Halyard sheaves and stay tangs shouldn't come into play, as they ought to be 'below' the masthead plate and out of the way.
It can be difficult to find places for all that other stuff, though. Most boats will have added extensions for, say, the windex and the VHF antenna, these can be simply aluminium or stainless bars, channel or whatever. Most wind instruments are on an extending vane anyway...
I'm not sure what the requirements are for separation of VHF antennas and lightning dissapators....
1984 Fast/Nicholson 345
Old 06-10-2011
Omatako's Avatar
Omatako will become famous soon enough
At the top of the masts on S/V Athena there is enough space to put a garden table and two chairs. It would be of value to know how big your mast is. But normally speaking:
The sheaves are inside the mast
The wind speed sensor sticks out the front
The windex sticks out the back
The VHF antenna goes straight up from the middle
The stay mountings are not on top but on the sides
And the lightning conductor I can't comment on because I've never had one.
Items 2 and 3 are often mounted to stainless plates fitted to the top of the mast and are not located on the mast itself.
As I said it depends on the size of the mast.
Arthur C. Clarke
Old 06-11-2011
john1066 is on a distinguished road
Mount the Windex on the VHF antenna (Metz and Windex AV, for instance), dispense with the bottle brush.
John
Old 06-11-2011
Boasun's Avatar
Boasun will become famous soon enough Boasun will become famous soon enough
One guy had an Osprey nest at the top of his mast. He was not allowed to use his boat until the young Osprey had flown the coup (nest). Then the authorities drove a piling next to his boat and moved the nest over to the top of the piling, because Osprey use the same nest every year.
1600 Ton Master, 2nd Mate Unlimited Tonnage
Maritime Instructor
S/V Rapture
Old 06-11-2011
SlowButSteady's Avatar
Senior Slacker
SlowButSteady is on a distinguished road
...and then there's the tricolor/strobe/anchor light, active radar reflector, AIS antenna (because antenna splitters are sooooo untrustworthy), WIFI antenna, FLIR, et cetera, et cetera, et cetera..... (whatever happened to KISS????)
(at least with all that up there, the gulls might not be able to find a place to light)
Old 06-11-2011
rikhall's Avatar
old guy :)
rikhall will become famous soon enough
You could get a ketch, a yawl or a schooner.
Irwin Citation 34
Mast Head Light Freesail99 Gear & Maintenance 21 03-27-2011 09:40 PM
Stepped mast, missing stuff. zz4gta Gear & Maintenance 0 04-28-2008 10:03 AM
Fractional Rig vs. Mast Head Rig c130king Sailboat Design and Construction 66 03-09-2008 11:38 AM
mast head sender mike dryver Gear & Maintenance 0 05-14-2006 06:37 PM
MAST HEAD CATALINA 38 sailnaway Gear & Maintenance 1 02-09-2006 01:23 PM
