06-11-2011
Originally Posted by SlowButSteady
That all depends on the calculator. Many will do this conversion, but often with a different key sequence. Some "scientific calculators" won't do it at all (not many, but a few). And when using some calculators, one has to be careful that the result isn't in radians rather than degrees.
You just proved the theory that you have to be 10% smarter than the toys you are playing with.
My Casio fx-300MS isn't that fussy. Enter the number, tap equal and then the degree button... No problem what so ever.
1600 Ton Master, 2nd Mate Unlimited Tonnage
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Maritime Instructor To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
S/V Rapture
