Old 06-13-2011
g0twind's Avatar
g0twind is on a distinguished road
Rig vibration during sail and at dock?
While out sailing in a slight breeze (10 knots or so) I noticed a vibration on the boat. The mainsail did not have it battens in and the leach was blowing around a bit. Could this be causing the boat to vibrate?
Then, while sitting down below at the dock the next day, i noticed a slightly different vibration. I went up on deck and could feel the mast vibrating when the wind blew. Is this normal?
This is the first year we have spent much time just hanging out at the dock, which is why I probably never noticed the vibration before....
1974 Paceship PY23 "Barely Awake"
Hull # 001
Old 06-13-2011
peterconway is on a distinguished road
what do sailboats and guitars have in common? they both have tight strings (shrouds), necks (mast) and acoustic chambers(hulls). add a little wind to activate the strings and music is made.
Old 06-13-2011
October Moon B43
MJBrown is on a distinguished road
Don't forget the topping lift. Too tight and it will sing.
Old 06-13-2011
Quite normal... some boats make more noise than others, some rigs will rattle quite a bit in a crosswind.
We chartered a C&C 38 one time, had a good sail and then moored for the night. We spent a half hour trying to find the pump we could hear running below only to figure out in the end it was rig vibration.
1984 Fast/Nicholson 345
Old 06-13-2011
Boasun's Avatar
Boasun will become famous soon enough Boasun will become famous soon enough
In port you will with a elipical mast with spreaders have various wind eddies along that mast and it will set up a vibration. Some harmonic and some not.
Move your halyards away from the mast, one way or another to stop them banging against the mast. It is very very annoying to have to listen to those halyards banging because some people can't, won't or ignorant of the practice of 'Good Neighbor Policies'.
1600 Ton Master, 2nd Mate Unlimited Tonnage
Maritime Instructor
S/V Rapture
Old 06-13-2011
g0twind's Avatar
The topping lift is pretty tight now that I think about it. I will loosen it a bit while at the dock.
I need to get some battens into the main to make sure the vibration while sailing goes away.
I always tie my halyards away from the mast, so not to bother all the "other" boaters....
Hull # 001
Old 06-13-2011
Barquito's Avatar
Barquito
Barquito is on a distinguished road
I was also suprised by the noise passing motor boats make.
Old 06-13-2011
i like to weave an old bungee cord thru the rigging while docked to muffle the vibs and clangs
Old 06-13-2011
Frogwatch is on a distinguished road
You'll know when you've been aboard for a long time when somebody points out the noise you no longer notice.
Old 06-13-2011
WDS123 is on a distinguished road
Rig tension ?
Rudder bearing ?
Vibration ! dbruce85 Boat Review and Purchase Forum 3 12-01-2008 11:14 PM
Vibration mtbmike Gear & Maintenance 7 05-28-2006 12:14 PM
Vibration mtbmike Gear & Maintenance 5 05-26-2006 11:55 AM
Cal 2-29, Faryman, Vibration sfwessel1951 Gear & Maintenance 2 03-18-2006 09:54 PM
Vibration dilemma lgsailor19 Gear & Maintenance 12 06-30-2004 09:02 AM
