06-20-2011
Tartan 27' owner
Second puddinlegs advice.
The only way to gain confidence for when you do get knocked down is to take the boat out and capsize it. Then right it by getting your weight on the center board.
Once you get really good at it you can lay the boat over while climbing onto the C/B, then climb back into the cockpit when it rights without actually getting in the water.
You will want to sail with the jib and main as using both sails will make your boat go even faster. When you start trying the jib try to get someone to go with you who can handle the jib sheets for you while you handle the main and tiller.
