Centerboard Keels - should I even consider? - Page 4 - SailNet Community
post #31 of 40 Old 06-21-2011
T37Chef's Avatar
Originally Posted by casey1999 View Post
Looks good to go according to Blue Water:
Search Results
And check this pic out- reason to have a centerboard (go to slide #3)!
New Page 1
I'm rather fond of that first link you posted Good find
Shawn
T37Chef is offline
post #32 of 40 Old 06-21-2011
72 C&C Corvette
CorvetteGuy's Avatar
A full length keel with a drop centerboard is great in many aspects between the ability to venture in the shalow waters with the ability to drop it and point well, centerboard boats are quite versitile, good luck on your purchase, but take everythin into consideration
CorvetteGuy is offline
post #33 of 40 Old 06-21-2011 Thread Starter
美国华人, 帆船 教授及输送
Yes, an informed decision is the correct decision even if it turns bad.
Fine Print:
I am old school. Integrity is to do the right thing even when no one is watching.
rockDAWG is offline
post #34 of 40 Old 06-21-2011 Thread Starter
美国华人, 帆船 教授及输送
[url=http://www.pelagic.co.uk/mediaplayer_fleet.asp
New Page 1[/url]
Linky is not werking
Fine Print:
rockDAWG is offline
post #35 of 40 Old 06-21-2011
T37Chef's Avatar
give it minute to load
Shawn
T37Chef is offline
post #36 of 40 Old 06-21-2011
casey1999's Avatar
If you did not find full description, here it is:
Tartan 37 Review : Bluewaterboats.org
casey1999 is offline
post #37 of 40 Old 06-21-2011
chef2sail's Avatar
Our C&C 35 is a k/c. It has great advantages in reducing weather helm and holding off normal reefing until 22 knots. It helps us point higher and gives us advantage when close hauled. We have never heard it banging or had any problems with it. It is weighted. It has a normal maintainence like ever other part of the boat. We change the pennant wire every five years whether it appears to need it or not. It is easy to drop as it has its own self tailing winch under the dodger on the cabintop. We do not have a problem with it boucing or rattleing.
A can find no disadvantage of it on our boat. As a side when racing other boats it has at times been the difference between the two.
Dave
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #38 of 40 Old 06-22-2011
TomMaine's Avatar
Unless you're lured by shallow water, I can't see buying a keel/cb boat.
A lot of good info here. Our lead keel with bronze board allows a whole ribbon of coastal area off limits to deeper draft boats. Anchorages, short cuts through shallow cuts, back waters to explore. In some places, that ribbon of coastal shoal water can open up to a significant area.
The cost is a bit more maintenance. My last pendant lasted 10 years and looked nearly new. I replaced the pin as well, and that was barely worn. Good insurance though.
While in the slings, I lower the board, haul and launch, and inspect. The bronze board weighs just over 300 pounds.
It can clunk on some points but that's an indication it's not adding much lift so it's raised partially.
We're a coastal sailing boat mostly Maine and southern New England so I don't worry about roll overs. The centerboard is down the list of things on my boat I would worry about if going off shore regularly.
A deep draft boat will point higher of course. The centerboard on our boat will on the average add 10 degrees to windward I've found over the years comparing 4' vs 8' centerboard draft on gps.
If you like to sail, it's just one more thing to tweak which I enjoy.
But again, the primary reason for me is the draft.
Here we are anchored on Cuttyhunk last summer at just a bit over 4' LW.
Anytime we're down that way, we never have trouble finding places to anchor even in the more crowded places around the Cape. We spent a couple days here just off from the crowded mooring field.
TomMaine is offline
post #39 of 40 Old 06-22-2011
Nice Looking Boat TomMaine...great lines...who's the designer/builder?
tempest is online now
post #40 of 40 Old 06-22-2011
TomMaine's Avatar
Thanks Tempest.
She's an Alden Challenger yawl. Aldens first fiberglass hull and deck, built in 1961.
TomMaine is offline
IP 38 Keels dave6330 Boat Review and Purchase Forum 2 01-03-2011 06:15 PM
PSC Keels Rogerr Pacific Seacraft 8 03-23-2010 08:24 PM
Iron Keels Versus Lead Keels twofish81 Gear & Maintenance 14 12-02-2007 02:58 PM
Iron Keels Versus Lead Keels twofish81 Sailboat Design and Construction 4 11-30-2007 11:55 AM
Fixed Keels vs. Swing Keels Dan Dickison Buying a Boat Articles 0 05-21-2001 09:00 PM
